As you have found out, changing the number of the file with a rev creates a lot of work. Rather than change the file name, save the file first to a folder with the rev number and keep working on the working copy in the active project folder. If you must have different file names leave the working copy as is and after copying rename the lower rev file only. So your working copy would always be M01 and then the revs would be M01A, M01B, etc.
