width factor in blocks
yawdapaah
hi,
we have some standard blocks in our office. when i insert them, the width factor in the blocks are not set to 1 as per my definition in "style". is there a way to change all text in all blocks to width factor 1?
thanks
i've tried battman before. it seems to reset all my blocks. sometimes, if i've mirrored it, the text appears mirrored. plus, i'd have to do this for every different type of block.
It will reset every instance of the block you edit.
Look at MIRRTEXT in the help files
"plus, i'd have to do this for every different type of block."Yes
