I'm running ACAD 2004 LT.
My dimension's are changing for no apparent reason. Create a drawing, add dimension's in paperspace, print, save, all works fine. When you go back to the drawing, the dimension (Not all) will be some random huge number. If I then match Prop's with another dimension that hasn't changed, it works fine again, until you open the drawing the next time.
I am completely baffled as to why this is happening, any idea's would be great.
Cheers,
Tom.
