Its usually based upon what information you need shown, or the type or work you do. That should be your primary determining factor.
Dates, project names or revision numbers are usually good. Also look at folder naming in conjunction with file naming. Folders can have submission dates in the name, while .dwg files can have sheet and project numbers in their file names.
Again, its entirely up to your company's needs.
