Results 1 to 4 of 4
    Senior Member
    Doove's Computer Details
    7
    HP Elitebook
    Intel i7 M620 2.67GHz
    8GB
    NVidia Quadro FX880M (512MB)
    Inventor 2011
    Oct 2008
    South Wales
    136
    Default Create a landscape mesh surface?
    Hi all
    I have a survey drawing in 3D; the contours are 3D polylines.
    The topo itself is of a square area of a hillside so the countours run through and are not closed.
    I would appreciate anyone's input on how to use these contours to create a landscape mesh surface or a solid.
    I'm not having much success with Loft etc.
    There are also lots of spot height blocks and I remember using a script to create a surface when I trained. Could I export the blocks x,y,z coords to a text file then run a script to create a mesh? The spot heights are not in a regular grid.
    Anyone done that before?
    Cheers
    Doove
    Forum Newbie
    AutoCAD 2017
    May 2017
    1
    I have exactly the same problem.
    Have you had any luck working out a way to do it?
    I have been creating a "grid" that uses 2d polylines with 50 or so cross sections - but this isnt perfect and takes ages.
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,018
    For me you dont have a 3d drawing you just have plines with z's.
    There are a few different ways to make 3dfaces interpreting all the vertice points, for me its CIV3D. But as you do not have that search here for Triang*.lsp by YMG which is a triangulation program. "TriangV0.5.9.lsp" you will need to convert your plines to 3d points again search for "Vertices of a pline.lsp"
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,881
    There might be something in CadTools that will do it. It's free, but a donation gets some additional functions.
  1. AutoCAD Tutorial: Create a mesh solid jar
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 23rd May 2009, 09:40 pm
  2. Explode Planar Surface To 3d Mesh
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Dec 2008, 12:25 pm
  3. How do I attatch or create Landscape in 2007
    By arjun_samar in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Dec 2008, 03:21 pm
  4. CONVERT PLANAR SURFACE TO MESH autocad
    Last Post: 23rd Oct 2008, 11:18 am
  5. Surface (mesh) to solid object
    By Slocad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Feb 2007, 01:27 pm
