srr Posted June 2, 2009 Share Posted June 2, 2009 Hello everyone I noticed by searching the forum there are alot of questions about linetypes not showing up correctly, but I could not find someone with my exact problem. While in model space, my dashed lines are dashed lines. When I set up a viewport in a layout, these dashed lines are solid. They also plot solid. Thank you, any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
azzro10 Posted June 2, 2009 Share Posted June 2, 2009 make sure PSLTSCALE & LTSCALE are set to 1 Quote Link to comment Share on other sites More sharing options...
rkent Posted June 2, 2009 Share Posted June 2, 2009 make sure PSLTSCALE & LTSCALE & MSLTSCALE are set to 1, you might try ltscale at .5 Quote Link to comment Share on other sites More sharing options...
srr Posted June 2, 2009 Author Share Posted June 2, 2009 These system variables are all set to 1 (I double checked), and I also tried ltscale at .5 but that also didn't help. Quote Link to comment Share on other sites More sharing options...
chelsea1307 Posted June 2, 2009 Share Posted June 2, 2009 double click inside your viewport set them and type regen Quote Link to comment Share on other sites More sharing options...
srr Posted June 2, 2009 Author Share Posted June 2, 2009 The lines are still apearing solid. Quote Link to comment Share on other sites More sharing options...
rkent Posted June 2, 2009 Share Posted June 2, 2009 post some of the drawing that displays that problem Quote Link to comment Share on other sites More sharing options...
srr Posted June 2, 2009 Author Share Posted June 2, 2009 The only dashed line in the part of the drawing I uploaded is over the front steps of the ground floor plan, like in my screenshots. EXAMPLE.dwg Quote Link to comment Share on other sites More sharing options...
srr Posted June 2, 2009 Author Share Posted June 2, 2009 I found just now that the problem was that I had checked "use paper space units for scaling" in the linetype manager. Sorry but thanks for the replies. Quote Link to comment Share on other sites More sharing options...
rkent Posted June 2, 2009 Share Posted June 2, 2009 I found just now that the problem was that I had checked "use paper space units for scaling" in the linetype manager. Sorry but thanks for the replies. I have that checked and it works fine to show linetypes. Anyway as long as you have it figured out. Quote Link to comment Share on other sites More sharing options...
