MikeP Posted June 8, 2009 Share Posted June 8, 2009 Ive dimensioned my drawing using an annotative dimension style. Now I would like to show my drawing in a viewport that is not set to the annotative scale. how can I have the viewport ignore the fact that the dimensions are annotative and display all the dimensions anyway???????????? Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 8, 2009 Share Posted June 8, 2009 are you saying that you want to display the annotation at a different scale that your viewport will be set to? if so, in the properties palette, you have an option to change either annotation scale and/or viewport scale separately. Quote Link to comment Share on other sites More sharing options...
MikeP Posted June 9, 2009 Author Share Posted June 9, 2009 are you saying that you want to display the annotation at a different scale that your viewport will be set to? if so, in the properties palette, you have an option to change either annotation scale and/or viewport scale separately. No, you have it backwards. I dimensioned in model space, now I just want to use a viewport and zoom to fit. Which object am I looking for to change the properties? When I zoom the viewport to the annotated scale, my drawing does not fit. So, I need to use a custom viewport scale, and display the dimensions. Si? Quote Link to comment Share on other sites More sharing options...
rkent Posted June 9, 2009 Share Posted June 9, 2009 Annotative dimensions will only show for the scales they have set for them. If you need a custom vp scale then grab all the dims and in properties add that custom scale and they will show. Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 10, 2009 Share Posted June 10, 2009 No, you have it backwards. I dimensioned in model space, now I just want to use a viewport and zoom to fit. Which object am I looking for to change the properties? When I zoom the viewport to the annotated scale, my drawing does not fit. So, I need to use a custom viewport scale, and display the dimensions. Si? zoom to fit then just manually set your viewport annotative scale. Quote Link to comment Share on other sites More sharing options...
jvli Posted January 12, 2010 Share Posted January 12, 2010 Check this setting (see atached jpg). Only took an hour to figure out. Thanks AutoDesk for driving me nuts, again. Quote Link to comment Share on other sites More sharing options...
