Results 1 to 5 of 5
    Full Member
    AutoCAD 2000
    Jan 2009
    49
    Default Dimensioning problem - AutoCad2000
    I am running Autocad 2000 and have copied and pasted a part of an existing drawing into a new drawing. When however I start to add dimensions to the new drawing the dimension is now appearing within an outline box and placed between the dimensioning arrows. How can I remove the outline box outline so that the dimension simply appears between the two arrow heads as before?
    Regards
    Stanier
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,471
    Try going into DIMSTYLE > Modify > Text tab. Look under Text Apperance and remove the checkmark in the box for Draw frame around text. Then click on the OK button and return to your drawing. You may have to update some existing entries but new entries should be fine. Does that do it for you?
    Senior Member
    AutoCAD 2000
    Nov 2008
    182
    First thing to do is to check the current "Dimstyle". Maybe you are currently using dimension style which you don't want.
    Second, is to use positve value for your DIMGAP variable.
    We learn more by looking for the answer to a question and not finding it than we do from learning the answer itself. ~Lloyd Alexander
    Full Member
    AutoCAD 2000
    Jan 2009
    49
    Hi all - Problem solved by unticking the frame box. Can't explain why I did not see it before but there you go.
    Many thanks
    Stanier
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,471
    Glad to hear the advice worked. Thank you for updating us.
  1. Dimensioning Problem
    By Pema Lama in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Mar 2008, 07:54 pm
  2. Dimensioning problem
    By joejoejoe in forum AutoCAD Beginners' Area
    Last Post: 4th Jan 2008, 10:25 pm
  3. dimensioning problem
    By salmoon in forum AutoCAD Drawing Management & Output
    Last Post: 4th Apr 2007, 10:30 pm
  4. Total beginner. Scale and Dimensioning problem.
    By ezzetabi in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jan 2007, 11:45 am
  5. irritating dimensioning problem
    By Nurbs in forum AutoCAD Drawing Management & Output
    Last Post: 13th Nov 2005, 11:15 pm
