Results 1 to 10 of 10
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    Default Make commandbutton called plot
    how can i make a commandbutton called plot when i press on it plot setup appear to me?
    Senior Member
    flowerrobot's Computer Details
    Windowns 7
    Lenovo W520
    Mechanical
    flowerrobot's Discipline Details
    Cad Manger
    Mechanical
    Mechanical 2013
    Sep 2007
    Sydney
    384
    In your cui, creat a button with some thing like "^^_plot", i belive
    or
    get the button that is already "plot" or maybe "print", and place that where you want
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    iam sorry i will explain more i have a form in vba and have commandbutton called plot i need press on it to get plot setup i try sendcommand but it work after i close my program is there any way to run it with my program
    thanks for help
    Senior Member Zorg's Avatar
    Zorg's Computer Details
    WinXP & Vista64
    AMD X2 2.6GHz
    2GB
    512Mb SLI
    500GB + 1TB External
    19"
    AutoCAD 2008
    Apr 2009
    United Kingdom
    301
    Quote Originally Posted by MR MAN View Post
    thanks for help
    Not, entirely sure what sort of end result you are after but if it's a button that will plot from a plot setup saved somewhere like 'A0', 'A1', 'A2', 'A3 then you need a lisp routine that wil ldo that for you
    Voila! The ZF-1.
  5. #5
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,816
    Mr MAN, Are you saying you want to bypass the plot setup and just have a "plot" button?
    Lee Mac Programming
    Just another Swamper
  6. #6
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    IAM SORRY FOR LATE IN REPLY
    DEAR LEE MAC I MAKE A BUTTON ITS NAME IS PLOT AS SHOWN
    Private Sub CommandButton5_Click()
    UserForm1.Hide
    ThisDrawing.SendCommand "_plot" & vbCr
    UserForm1.Show
    End Sub
    IT OPEN MENU OF PLOT FOR ME UNTIL I CHOOSE WHAT I NEED MY PROBLEM IS WHEN I NEED TO PREVIEW OR MAKE PLOT AREA NO ACTION TAKEN UNTIL I CLOSE MY PROGRAM
    HAVE ANY IDEA TO SOLVE THIS
    THANKS FOR HELP
  7. #7
    Super Member SEANT's Avatar
    AutoCAD 2012
    Aug 2005
    Rhode Island
    1,971
    Instead of SendCommand, have you looked into the DisplayPlotPreview method of the Application.Document.Plot object (ThisDrawing.Plot.DisplayPlotPreview acFullPreview).
  8. #8
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    Can You Please Explain More Seant?
    How Can I Make It Exactly?
    Thanks For Help
  9. #9
    AutoCAD 2012
    Aug 2005
    Rhode Island
    1,971
    Sadly, it appears that Autodesk has managed to break the DisplayPlotPreview method somewhere between AutoCAD 2004 and 2009.
    Code:
    Sub DisplayPlotPreview()
        Dim objPlot As AcadPlot
        Dim AddedLayouts() As String
        Dim LayoutList As Variant
        Dim oLayout As AcadLayout
        Dim ArraySize As Integer
        Dim objConfig As AcadPlotConfiguration
        Dim colPlotConfigs As AcadPlotConfigurations
        Set colPlotConfigs = ThisDrawing.PlotConfigurations
       If colPlotConfigs.count = 0 Then
          colPlotConfigs.Add "TestConfig"
       End If
        Set objConfig = ThisDrawing.PlotConfigurations.Item("TestConfig")
        For Each oLayout In ThisDrawing.Layouts
            ArraySize = ArraySize + 1
            ReDim Preserve AddedLayouts(1 To ArraySize)
            AddedLayouts(ArraySize) = oLayout.Name
        Next
        LayoutList = AddedLayouts
        Set objPlot = ThisDrawing.Plot
        objPlot.SetLayoutsToPlot LayoutList
        objPlot.DisplayPlotPreview acFullPreview 'works in 2004, error in 2009
    End Sub
  10. #10
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    THANKS SEANT BUT IT DOESN'T WORK WITH AUTOCAD 2007
    THANK YOU AGAIN FOR YOUR HELP
  1. Is there anyway to make a program make an edited dimension standout?
    By BLOACH85 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th May 2009, 05:42 pm
  2. Working with so called "adaptive" wiring
    By Devented in forum Autodesk Inventor
    Last Post: 28th Apr 2009, 04:47 pm
  3. I don't know what its called that I need help with sorry
    By malachai in forum AutoCAD Beginners' Area
    Last Post: 22nd Jan 2008, 04:09 pm
  4. What are thsse things called?
    By JamFam in forum AutoCAD Beginners' Area
    Last Post: 25th Mar 2006, 05:20 am
  5. Looking for a block - not sure what it's called in English
    By roel in forum AutoCAD Drawing Management & Output
    Last Post: 7th Mar 2006, 10:40 am
