solid overwriting lines
qwerty
I have one file where I can't get grey hatches to stop overwriting lines and text. The others in our office have had a go at the problem too. We've tried all the usual fixes: draworder, xref order, wblock out to change display order, created a new DWG and put entities back in order... nothing works.
Normal style by adding ,N to the pattern name in the HPNAME
system variable.
See the help section for Hatch>other options.
I assume that the layer is turned on. This issue is you are unable to bring to the front - the drawing order basiclly.
Would it be possible to send me a copy of the draw? That way I can try and see all settings of the drawing. And see if it is an AutoCAD issue.
