Results 1 to 4 of 4
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    Default how can i make this with vba?
    i have listbox and i need make button apply any command on *.dwgs files in this listbox
    thanks
    Senior Member
    AutoCAD 2007
    Jan 2007
    159
    Code:
    dim fil as file
    for each c in listbox1.items
       fil.open(c)
        ;do something
       fil.save
       fil.close
    next c
    I haven't tested this but it will be close to what you need
    Where are the items in the list box coming from
    Ollie
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    Thanks Ollie But It Doesn't Work
    Senior Member
    AutoCAD 2007
    Jan 2007
    159
    Code:
    For Each c In ComboBox1.List
    msgbox c     ;
    Next c
    Sorry about that, I've tried this and it works
  1. Is there anyway to make a program make an edited dimension standout?
    By BLOACH85 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th May 2009, 05:42 pm
  2. make my own cui
    By MR MAN in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Oct 2008, 08:35 am
  3. How do I make....
    By Lora_D in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Mar 2008, 01:48 am
  4. How to make...
    By Milon in forum AutoCAD Beginners' Area
    Last Post: 23rd Feb 2005, 09:26 am
