Results 1 to 2 of 2
    madriver
    Default lisp loading problem...simple I'm sure..
    For some reason one and only one of my lisp routines will not load. It used to. Anyway, here is the error message...
    _Dnote
    AutoLISP Error: quit / exit abort; error: An error has occurred inside the
    *error* functionAutoCAD variable setting rejected: "blipmode" nil
    Command:
    Any Ideas?
    Thanks
    Bob
    SpeedCAD
    Default Re: lisp loading problem...simple I'm sure..
    Quote Originally Posted by madriver
    _Dnote
    Command:
    Any Ideas?
    Thanks
    Bob
    Hi...
    you have problem with BLIPMODE variable, it can't to be "nil". Anyway you must delete it of your code, you don't need the BLIPMODE variable now...
