Manipulating dimension values
silverfish
Firstly I would like to say hi to all here. My first post.....
I work within the fire protection industry and do loads of 2d pipe layouts.
I have created a dimension style without any lines and leaders to insert above the pipe. I have a suffix of the pipe diameter followed by an x.eg 32x then the dimension value...32x3000
What I need to do is subtract a value from the 3000 to represent the cut pipe length....32x2950
This subtracted value is to allow for deductions on screwed fittings.
Is there a way to take the dimension value ie 3000mm and subtract a value of say 50mm off of it without doing an overide.
Our drawings have hundreds of these cut lenghts and it would be too time consuming.
I hope that my explanation is clear enough.....:wink:
Thanks
Bruce
  • Replies 25
  • Lee Mac
    9
  • silverfish
    8
  • Ryder
    4
  • irneb
    3
Posted Images
Something like this?
(defun c:MacDim (/ ss num)
 (vl-load-com)
 (if (and (setq ss (ssget '((0 . "DIMENSION"))))
          (setq num (getreal "\nSpecify Alteration: ")))
   (mapcar
     (function
       (lambda (x)
         (vla-put-TextOverride x
           (rtos (+ (vla-get-Measurement x) num)))))
     (mapcar 'vlax-ename->vla-object
       (vl-remove-if 'listp
         (mapcar 'cadr (ssnamex ss))))))
 (princ))
Hi Lee,
Many thanks! Just tried it and it works except that once I select the dimension ie, 32x3000 and subtract 50 off of it I get 2950.000.
I lose the prefix and formatting.
Is there a way of setting up a dim style to deduct a certain value?
Regards
Bruce
I'm not sure how to set up the dimension style so that it subtracts the value, but you could give this a try in any case:
 (vl-load-com)
   (mapcar
     (function
       (lambda (x)
           (strcat
             (vla-get-TextPrefix x)
                  (vla-get-UnitsFormat x)
                     (vla-get-PrimaryUnitsPrecision x))
                 (vla-get-TextSuffix x)))))
 (princ))
As a variant it is possible to arrive thus:
1. To consider the size as the block (*D...). The block name is stored in dxf a code 2
2. To find in the table of blocks its description, and in it mtext and to take its value.
(defun C:TEST ( / dim str)
 (and
   (setq dim (car (entsel "\nSelect dimention:")))
   (= (cdr(assoc 0 (entget dim))) "DIMENSION")
   (setq str (dim-get-text-string dim))
 (princ str)
(defun dim-get-text-string ( dim / str)
(setq str "")
  [color="Red"](vlax-for item (vla-item (vla-get-blocks
                        (vla-get-activedocument (vlax-get-acad-object))
                      ) ;_ end of vla-get-Blocks
                      (cdr (assoc 2 (entget dim)))
            ) ;_ end of vla-item
    (if (vlax-property-available-p item 'Textstring)
         (setq str (vla-get-textstring item))[/color]
(mip_MTEXT_Unformat str)
(defun mip_MTEXT_Unformat ( Mtext / text Str )
 (setq Text "")
  (while (/= Mtext "")
       (cond
         ((wcmatch (strcase (setq Str (substr Mtext 1 2))) "\\[\\{}]")
           (setq Mtext (substr Mtext 3) Text   (strcat Text Str)))
         ((wcmatch (substr Mtext 1 1) "[{}]")(setq Mtext (substr Mtext 2)))
         ((wcmatch (strcase (setq Str (substr Mtext 1 2))) "\\[LO`~]")
   (setq Mtext (substr Mtext 3)))
         ((wcmatch (strcase (substr Mtext 1 2)) "\\[ACFHQTW]")
           (setq Mtext (substr Mtext (+ 2 (vl-string-search ";" Mtext)))))
  ((wcmatch (strcase (substr mtext 1 4)) "\\PQ[CRJD],\\PXQ")  ;;;Add by KPblC
   (setq mtext (substr mtext (+ 2 (vl-string-search ";" mtext))))
         ((wcmatch (strcase (substr Mtext 1 2)) "\\P")
           (if (or
	   (zerop (strlen Text))
	   (= " " (substr Text (strlen Text)))
	   (= " " (substr Mtext 3 1)))
              (setq Mtext (substr Mtext 3) Text (strcat Text " "))))
  ((wcmatch (strcase (substr Mtext 1 2)) "\\S")
           (setq Str   (substr Mtext 3 (- (vl-string-search ";" Mtext) 2))
                 Text  (strcat Text (vl-string-translate "#^\\" "/^\\" Str))
                 Mtext (substr Mtext (+ 4 (strlen Str)))))
  (t (setq Text (strcat Text (substr Mtext 1 1)) Mtext (substr Mtext 2)))))
 Text)
Very nice VVA, but surely even with the Dimension Text String, you still have to do the Maths on it and that would mess with the formatting. :unsure:
Thanks for the input Guys!
VVA = Loaded your lisp but got errors when trying to run it?
Lee - Loaded your second version and works a treat.
I have created different layers for the various diameters and now switch all other layers off and use your routine to multiple select all relevent dimensions that require the same deduction!
Again, many thanks to you both
silverfish
silverfish
Hey Bruce,
Glad I could help out - I think VVA's LISP was more to provide me with help on a different way to extract the relevant information from the dimension, but I'm happy that my code met your requirements :)
Lee
> Lee Mac
  • 2 weeks later...
Lee,
I have been using your routine with great success...Thank you!
I have another request!
Is it possible to change the dimension colour once I have run the lisp file on it?
I am getting a little confused as to which dimension I have worked on and which not!
Thanks
silverfish
Not a problem :)
 (vl-load-com)
   (mapcar
     (function
       (lambda (x)
         (vla-put-ExtensionLineColor x 1) ;; <<-- 1 = Red
           (vla-put-DimensionLineColor x 1)
           (strcat
 (princ))
Thanks Lee,
What I'm looking for is to change the dim text colour not the extension lines as I have set the dim style up to turn off all extension lines, leaders and arrow heads so all you see is this "25x3000" which is what I want changed.
Many Thank
silverfish
Thanks Lee,
Many Thank
silverfish
Sorry, I wasn't exactly sure what you wanted. - Its not hard to change it, no worries :)
Here ya go:
 (vl-load-com)
   (mapcar
     (function
       (lambda (x)
         (vla-put-TextColor x 1) ; <<-- 1 = Red
             (strcat
 (princ))
Thanks again Lee, works perfectly!
Perhaps you can answer this question I have.
When doing the dimension is it possible to have the prefix above the line and the dimension value below the line.
many thanks
Use: "\X" like this:
 (vl-load-com)
   (mapcar
     (function
       (lambda (x)
             (strcat
               (vla-get-TextPrefix x) "\\X"
 (princ))
You are truly a wizzard at this Lee! CHEERS
Every time you help me on this I find I have another request......;-)
Is it possible to move the prefix to a layer named "FPS SPRINKLER DIA" and the dimension value to a layer named "FPS SPRINKLER LIST"
Many thanks
Bruce
Many thanks
Bruce
The dimension is a single entity, and on its own layer, so without making the prefix and dimension strings out of separate entities, I don't think this is possible.
  • 3 years later...
Hi Guys
I am too in the fire protection industry and have the same query as Bruce.
I am well trained in Autocad but unfortunately my knowledge with regards to programming is very limited. Could you perhaps walk me through loading a LISP?
Lee im on your website amd i am attempting to do it.
Thanks In advance:D
