Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 26
  1. #11
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,729
    Not a problem
    Code:
    (defun c:MacDim (/ ss num)
      (vl-load-com)
      (if (and (setq ss (ssget '((0 . "DIMENSION"))))
               (setq num (getreal "\nSpecify Alteration: ")))
        (mapcar
          (function
            (lambda (x)
              (vla-put-ExtensionLineColor x 1) ;; <<-- 1 = Red
                (vla-put-DimensionLineColor x 1)
              (vla-put-TextOverride x
                (strcat
                  (vla-get-TextPrefix x)
                    (rtos (+ (vla-get-Measurement x) num)
                       (vla-get-UnitsFormat x)
                          (vla-get-PrimaryUnitsPrecision x))
                      (vla-get-TextSuffix x)))))
          (mapcar 'vlax-ename->vla-object
            (vl-remove-if 'listp
              (mapcar 'cadr (ssnamex ss))))))
      (princ))
    Lee Mac Programming
    Just another Swamper
  2. #12
    Forum Newbie
    AutoCAD 2009
    Jun 2009
    8
    Thanks Lee,
    What I'm looking for is to change the dim text colour not the extension lines as I have set the dim style up to turn off all extension lines, leaders and arrow heads so all you see is this "25x3000" which is what I want changed.
    Many Thank
    silverfish
  3. #13
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,729
    Quote Originally Posted by silverfish View Post
    Thanks Lee,
    Many Thank
    silverfish
    Sorry, I wasn't exactly sure what you wanted. - Its not hard to change it, no worries
    Lee Mac Programming
  4. #14
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,729
    Here ya go:
    Code:
      (vl-load-com)
        (mapcar
          (function
            (lambda (x)
              (vla-put-TextColor x 1) ; <<-- 1 = Red
                  (strcat
      (princ))
    Lee Mac Programming
  5. #15
    Forum Newbie
    AutoCAD 2009
    Jun 2009
    8
    Thanks again Lee, works perfectly!
    Perhaps you can answer this question I have.
    When doing the dimension is it possible to have the prefix above the line and the dimension value below the line.
    many thanks
  6. #16
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,729
    Use: "\X" like this:
    Code:
      (vl-load-com)
        (mapcar
          (function
            (lambda (x)
                  (strcat
                    (vla-get-TextPrefix x) "\\X"
      (princ))
    Lee Mac Programming
  7. #17
    Forum Newbie
    AutoCAD 2009
    Jun 2009
    8
    You are truly a wizzard at this Lee! CHEERS
    Every time you help me on this I find I have another request......;-)
    Is it possible to move the prefix to a layer named "FPS SPRINKLER DIA" and the dimension value to a layer named "FPS SPRINKLER LIST"
    Many thanks
    Bruce
  8. #18
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,729
    Many thanks
    Bruce
    The dimension is a single entity, and on its own layer, so without making the prefix and dimension strings out of separate entities, I don't think this is possible.
    Lee Mac Programming
  9. #19
    Forum Newbie
    AutoCAD 2009
    Jun 2009
    8
    Thanks Lee. Much appreciated.
    bruce
  10. #20
    Forum Newbie
    AutoCAD 2011
    Aug 2012
    4
    Hi Guys
    I am too in the fire protection industry and have the same query as Bruce.
    I am well trained in Autocad but unfortunately my knowledge with regards to programming is very limited. Could you perhaps walk me through loading a LISP?
    Lee im on your website amd i am attempting to do it.
    Thanks In advance
  1. Manipulating JPEGs in Autocad
    By Jovial in forum AutoCAD Beginners' Area
    Last Post: 9th Mar 2009, 03:50 pm
  2. Changing values in Linear Dimension
    By Evil_eyes in forum AutoCAD Beginners' Area
    Last Post: 9th Feb 2009, 11:43 pm
  3. How to convert Latitude / Longitude values in to Northing / Easting values in meters
    By Chenna Siva Koteswara rao in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Dec 2008, 11:09 pm
  4. Manipulating Autocad from Excel
    By Joro-- in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Nov 2005, 11:01 pm
  5. Manipulating my background
    By hyposmurf in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Jun 2004, 07:21 pm
