Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Full Member
    AutoCAD 2009
    Apr 2009
    82
    Default Match Text Height, Width & Oblique
    Hi All,
    Please help me regarding that when im using match properties to match the Width, Height or Oblique of Mtext and Attributes it will not change or match the text i want,
    Please provide me some route that will match the fonts Style,Effects and sizes of multitext or attribute
    Thank you all
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,406
    Match Properties should be able to accomplish this task - make sure that Text is ticked in the Match Properties Settings.
    Quote Originally Posted by VisDak View Post
    Please provide me some route that will match the fonts Style,Effects and sizes of multitext or attribute...
    This is not a LISP Supermarket - but more a help and advice site.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Full Member
    AutoCAD 2009
    Apr 2009
    82
    Yes Lee,
    its all ticked and the Text are checked on Match Properties Settings, i dont understand also, i also used the 2009 version same situation maybe the text width and oblique aré not included in Match properties,
    see image,
    Thanks lee,
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,406
    I was experimenting with different ways to code this type of program, and with the advice of some of the guys over at the Swamp, this is what I came up with:
    Code:
    (defun c:mtxt (/ tEnt tObj ss)
      (vl-load-com)
      (if (and (setq tEnt (car (entsel "\nSelect Source Text: ")))
               (wcmatch (cdadr (entget tEnt)) "ATT*,*TEXT")
               (setq tObj (vlax-ename->vla-object tEnt)))
        (while (setq ss (ssget '((0 . "*TEXT,ATT*"))))
          (foreach Obj (mapcar 'vlax-ename->vla-object
                         (vl-remove-if 'listp
                           (mapcar 'cadr (ssnamex ss))))
            (foreach fun '(Layer Color Height ObliqueAngle ScaleFactor StyleName)
              (if (and (vlax-property-available-p tObj fun)
                       (vlax-property-available-p Obj fun t))
                (vlax-put-property Obj fun
                  (vlax-get-property tObj fun))))))
        (princ "\n<< Nothing Selected >>"))
      (princ))
  5. #5
    Full Member
    AutoCAD 2009
    Apr 2009
    82
    Hi All,
    Good Day to all, i have here a Lisp route the will modify all the text width factor but only works on Dtext, not applicable on Mtext and Attribute,
    Kindly Please arrange this code so that it will be used also on Mtext attributes and Dimensions, thanks all
    Code:
    (defun c:chw (/ ennyi23 wb23 shell23 loui23 el23)
     (initget 7)
     (prompt "\nSelect text(s).... ")
      (command "select" "au" pause)
      (setq ennyi23 (ssget "p"))
      (setvar "cmdecho" 0)
      (initget 7)
      (setq wb23 (getdist "\nEnter New Width Factor: "))
      (setq shell23 (sslength ennyi23))
      (prompt "\nChanging width of selected texts... stand by.")
      (command "undo" "mark")
      (setq loui23 0)
          (while (< loui23 shell23)
            (setq el23 (entget (ssname ennyi23 loui23)))
            (if (= "TEXT" (cdr (assoc 0 el23)))
                (setq el23 (subst (cons 41 wb23) (assoc 41 el23) el23))
                (entmod el23)
            (setq loui23 (1+ loui23))
      (setvar "cmdecho" 1)
    Full Member
    AutoCAD 2009
    Apr 2009
    82
    Thank Lee,
    the code is work on Dtext , on Mtxt and Att, are not, but i like it is a dynamic match text properties,
    (Layer Color Height ObliqueAngle ScaleFactor StyleName) this will be great when this route are also applicalbe on Mtxt and Att.
    many thanks Lee,
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,406
    Thank Lee,
    many thanks Lee,
    MTEXT is difficult as the formatting is achieved through the TextString, and not by separate properties.
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,406
    Try this one - source cannot be MTEXT.
    Code:
      (vl-load-com)
      (if (and (setq tEnt (car (nentsel "\nSelect Source Text: ")))
               (wcmatch (cdadr (entget tEnt)) "ATT*,TEXT")
        (while (setq Obj (car (nentsel "\nSelect Destination Object: ")))
          (setq Obj (vlax-ename->vla-object Obj))
          (cond ((vl-position (vla-get-ObjectName Obj)
                   '("AcDbAttribute" "AcDbText" "AcDbMText"))
                (if (eq (vla-get-ObjectName Obj) "AcDbMText")
                 (vla-put-TextString Obj
                   (strcat "{\\Q"
                     (rtos (rtd (vla-get-ObliqueAngle tObj))) ";\\W"
                       (rtos (vla-get-ScaleFactor tObj)) ";"
                         (mip_mtext_unformat (vla-get-TextString Obj)) "}"))))
                (t (princ "\nMissed, Try Again..."))))
      (princ))
    (defun mip_MTEXT_Unformat ( Mtext / text Str )
      (setq Text "")
       (while (/= Mtext "")
            (cond
              ((wcmatch (strcase (setq Str (substr Mtext 1 2))) "\\[\\{}]")
                (setq Mtext (substr Mtext 3) Text   (strcat Text Str)))
              ((wcmatch (substr Mtext 1 1) "[{}]")(setq Mtext (substr Mtext 2)))
              ((wcmatch (strcase (setq Str (substr Mtext 1 2))) "\\[LO`~]")
           (setq Mtext (substr Mtext 3)))
              ((wcmatch (strcase (substr Mtext 1 2)) "\\[ACFHQTW]")
                (setq Mtext (substr Mtext (+ 2 (vl-string-search ";" Mtext)))))
          ((wcmatch (strcase (substr mtext 1 4)) "\\PQ[CRJD],\\PXQ")  ;;;Add by KPblC
           (setq mtext (substr mtext (+ 2 (vl-string-search ";" mtext)))))
              ((wcmatch (strcase (substr Mtext 1 2)) "\\P")
                (if (or
               (zerop (strlen Text))
               (= " " (substr Text (strlen Text)))
               (= " " (substr Mtext 3 1)))
                   (setq Mtext (substr Mtext 3) Text (strcat Text " "))))
          ((wcmatch (strcase (substr Mtext 1 2)) "\\S")
                (setq Str   (substr Mtext 3 (- (vl-string-search ";" Mtext) 2))
                      Text  (strcat Text (vl-string-translate "#^\\" "/^\\" Str))
                      Mtext (substr Mtext (+ 4 (strlen Str)))))
          (t (setq Text (strcat Text (substr Mtext 1 1)) Mtext (substr Mtext 2)))))
      Text)
    (defun rtd (x)
      (* 180. (/ x pi)))
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,406
    As an upgrade, this can match MTEXT to MTEXT and DTEXT/ATTRIB* to MTEXT.
    Only thing left is MTEXT -> DTEXT/ATTRIB* (the hardest one )
    Code:
      (vl-load-com)
                   '("AcDbAttribute" "AcDbAttributeDefinition" "AcDbText" "AcDbMText"))
                 (cond ((and (eq (vla-get-ObjectName Obj) "AcDbMText")
                             (vl-position (vla-get-ObjectName tObj)
                               '("AcDbAttributeDefinition" "AcDbAttribute" "AcDbText")))
                          (strcat "{\\Q"
                       ((= (vla-get-ObjectName Obj) (vla-get-ObjectName tObj) "AcDbMText")
                          (vl-String-Subst
                            (mip_mtext_unformat
                                (mip_mtext_unformat
                                  (vla-get-TextString tObj))
                                    (vla-get-TextString tObj))))))
      (princ))
      (setq Text "")
            (cond
                (if (or
      Text)
    (defun rtd (x)
      (* 180. (/ x pi)))
  10. #10
    Full Member
    AutoCAD 2009
    Apr 2009
    82
    Thank Lee,
    Yes it works i'll be using Dtext source, to match destinations of Mtxt and attributes, Great Lee
    Cheers
  1. 3D modeling and length, width, height question
    By deadseasquirrels in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Feb 2012, 08:40 pm
  2. Height and Width of cell
    By guyzen2004 in forum AutoCAD General
    Last Post: 19th Sep 2007, 04:22 pm
  3. Match Polyline Width
    By Brunello19 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Nov 2005, 02:27 pm
  4. Attribute height and width factor - changing many at once?
    By Kad in forum AutoCAD Drawing Management & Output
    Last Post: 30th Aug 2005, 12:01 pm
  5. Oblique Text
    By chixwithtrix in forum AutoCAD General
    Last Post: 6th Apr 2005, 02:51 am
