Auto Numbering?
AQucsaiJr
I have the need of a way to create a string of text in a number sequence. I am working with Termination Racks that have, on average, 42 points. The term racks are numbered vertically 1-42. The number very however... i.e. the term rack could be numbered 1-42, 43-84 and so on... There are 42 points to be assigned numbers and as long as the list can be populated vertically or horizontally, it will work for me. I have attached an image of what a topical term rack looks like... The number sequence on this one is declining from top to bottem, but I ussually make them asend from top to bottem.
  • Replies 126
  • Lee Mac
    43
  • AQucsaiJr
    34
  • fuqua
    19
  • tony barretto
    5
Posted Images
Here's an old one I wrote, could be modified to "auto-number".
;; ============ Num.lsp ===============
;;  FUNCTION:
;;  Will sequentially place numerical
;;  text upon mouse click, with optional
;;  prefix and suffix.
;;  SYNTAX: num
;;  AUTHOR:
;;  Copyright (c) 2009, Lee McDonnell
;;  (Contact Lee Mac, CADTutor.net)
;;  PLATFORMS:
;;  No Restrictions,
;;  only tested in ACAD 2004.
;;  VERSION:
;;  1.0  ~  05.04.2009
(defun c:num  (/ vlst ovar dVars tmpVars pt)
 (setq    vlst '("OSMODE" "CLAYER")
   ovar (mapcar 'getvar vlst))
 (setvar "OSMODE" 0)
 (or (tblsearch "LAYER" "NumText")
     (vla-put-color
   (vla-add
     (vla-get-layers
       (vla-get-ActiveDocument
         (vlax-get-acad-object))) "NumText") acYellow))
 (setq dVars '(sNum inNum Pref Suff))
 (mapcar '(lambda (x y) (or (boundp x) (set x y))) dVars '(1 1 "" ""))
 (setq tmpVars (list (getreal (strcat "\nSpecify Starting Number <" (rtos sNum 2 2) ">: "))
             (getreal (strcat "\nSpecify Increment <" (rtos inNum 2 2) ">: "))
             (getstring (strcat "\nSpecify Prefix <" (if (eq "" Pref) "-None-" Pref) ">: "))
             (getstring (strcat "\nSpecify Suffix <" (if (eq "" Suff) "-None-" Suff) ">: "))))
 (mapcar '(lambda (x y) (or (or (not x) (eq "" x)) (set y x))) tmpVars dVars)
 (while (setq pt (getpoint "\nClick for Text... "))
   (Make_Text pt (strcat Pref (rtos sNum 2 2) Suff))
   (setq sNum (+ sNum inNum)))
 (mapcar 'setvar vlst ovar)
 (princ))
(defun Make_Text  (txt_pt txt_val)
 (entmake (list '(0 . "TEXT")
        '(8 . "NumText")
        (cons 10 txt_pt)
        (cons 40 (max 2.5 (getvar "TEXTSIZE")))
        (cons 1 txt_val)
        '(50 . 0.0)
        (cons 7 (getvar "TEXTSTYLE"))
        '(71 . 0)
        '(72 . 1)
        '(73 . 2)
        (cons 11 txt_pt))))
As a quick modification - haven't got time:
;;  FUNCTION:
;;  SYNTAX: num
;;  AUTHOR:
;;  PLATFORMS:
;;  No Restrictions,
;;  only tested in ACAD 2010.
;;  VERSION:
;;  1.0  ~  05.04.2009
;;  2.0  ~  15.06.2009
(defun c:num  (/ dVars tmpVars pt ang sNum*)
 (setq dVars '(sNum eNum inNum Spc Dir))
 (mapcar '(lambda (x y) (or (boundp x) (set x y))) dVars '(1 10 1 1 "X"))
                     (getreal (strcat "\nSpecify Ending Number <" (rtos eNum 2 2) ">: "))
                     (getreal (strcat "\nSpecify Spacing <" (rtos Spc 2 2) ">: "))))
 (initget "X Y")
 (setq tmpVars
   (append tmpVars (list (getkword (strcat "\nSpecify Direction [X/Y] <" Dir ">: ")))))
 (mapcar '(lambda (x y) (or (not x) (set y x))) tmpVars dVars)
 (if (eq Dir "X") (setq ang 0) (setq ang (/ pi 2)))
 (if (setq pt (getpoint "\nSpecify Start Point: ") i 0 sNum* sNum)
   (while (<= sNum* eNum)
     (Make_Text (polar pt ang (* i Spc)) (rtos sNum* 2 2))
     (setq sNum* (+ sNum* inNum) i (1+ i))))
 (princ))
(defun Make_Text  (pt val)
 (entmake
   (list
     (cons 0 "TEXT")
     (cons 8 (getvar "CLAYER"))
     (cons 10 pt)
     (cons 62 2)
     (cons 40 (getvar "TEXTSIZE"))
     (cons 1 val)
     (cons 50 0.0)
     (cons 71 0)
     (cons 72 1)
     (cons 73 2)
     (cons 11 pt))))
Oh that is perfect... Thank you... Where can I learn to edit LISP files? I would like to have this also ask for a text style, size, and layer instead of creating a new layer and assuming text style and size.
I also like the Prefix and sufix in the first code... I guess I should really just learn how to write the code... Thanks for your help!
May not be the right sub-forum for this but if you are using LT and so can't use lisps try the following two tips-
1/
Put the following string on a user defined menu button.
*^C^C_text;\;;$M=$(+,$(getvar,USERI1),1);setvar;US ERI1;$M=$(+,$(getvar,USERI1),1);
This puts a new text with an incremented value on the drawing with each click of your mouse.
You can also use SETVAR to change USERI1 to 1 below whatever initial value you want.
2/
This one increments text that is already on the drawing
*^C^C_.Change;\;;;;;;$M=$(getvar,USERI1);_.Setvar; USERI1;$(+,1 ,$(getvar,USERI1))
This time though set USERI1 to the value you want to start with.
I do not take credit for these button macros; I found them some time ago on another website. But they are well worth sharing.
I can easily modify my LISP to incorporate Prefix/Suffix, and other prompts - just haven't got much time at the moment :wink:
You can learn LISP on many sites - AfraLISP, Jeffery Sanders to name a few.
cool... Well if you do get a lil extra time just let me know... I'll keep this thread in fav to reference it later... If I havn't figured it out by then... I'll look into these places you mentioned... I am interested in writing the LISP's myself as this is not the only one I could use to speed up my drafting process.. I apretiate what you have given me, it is a very good start to what I would lokie to use. Thank you.
thats a great tool ! but i need some adjusting to it, being a complete lisp noob myself i hope someone can help me.
i dont want it to show the nummer behind the dot ie: 123456.00 i just need the first row of numbers without the .00 part. anyone know how i can "demolish" this ?
also the text height is 267 (thats waaay to big) can anyone adjust this for me or tell me how ofcourse :)
thanx in advance.
Hey Fuqua,
To covert a real number or an integer to a string the function RTOS is used. RTOS takes 3 argument (rtos number mode precision)
In your case you need to change the precision.
For example
(rtos pi 2 2) returns "3.14"
(rtos pi 2 0) returns "3"
The part of the code that needs to be updated is
sweet thank you ! that did the trick :D
im having 1 more little problem, the justify is on center and left, i just need it to be left. As far as i can see there is no line in the lisp for this, can i add this to it ?
i have found this tool to change the justification of m and dtext i believe, but it is to much for me, all i need is 1 line to add to the autocounter tool to set the justify at left.
;                       ***  JUSTIFY.LSP  ***
; Changes the justification of text to:-
;       Left, Center, Right, Aligned, Middle, Fit,
;       Bottom left, center or right,
;       Middle left, center or right, OR
;       Top left, center of right
(defun C:JUSTIFY (/ a a1 a2 a3 a4 t m n n1 p1
                   p q j j0 n2 j1 j2 q1 index dummy)
 (setvar "cmdecho" 0)
 (graphscr)
 (prompt "\n *  Select text to change justification...")(terpri)
 (setq t (ssget))
 (if $just
   (setq dummy nil)
   (setq $just "C")
 (prompt "\n *  Enter appropriate letter or select from pull down menu...")
 (initget "L C R A M F BL BC BR ML MC MR TL TC TR")
 (setq j1 (getkword (strcat
   "\n *  L/C/R/M/A/F/BL/BC/BR/ML/MC/MR/TL/TC/TR: <" $just "> ")))
 (if (= j1 "")
   (setq j1 $just)
   (setq $just j1)
 (setq m (sslength t)
       index 0)
 (repeat m
   (setq a (entget (ssname t index))
         p (cdr (assoc 0 a)))
   (if (= p "TEXT")
        (setq j (assoc 72 a)
              j2 (assoc 73 a)
              p (assoc 10 a)
              q (assoc 11 a)
              j0 (cdr j))
        (if (or (= j1 "L")(= j1 "C")(= j1 "R")(= j1 "M")
                (= j1 "BL")(= j1 "BC")(= j1 "BR")
                (= j1 "ML")(= j1 "MC")(= j1 "MR")
                (= j1 "TL")(= j1 "TC")(= j1 "TR"))
          (if (= j0 0)
              (setq p1 (cdr p)
                    q1 (cons (car q) p1)
                    n1 (subst q1 q a))
              (setq q1 (cdr q)
                    p1 (cons (car p) q1)
                    n1 (subst p1 p a))
        (if (or (= j1 "A")(= j1 "F"))
            (prompt "\n ")
            (prin1 (+ index 1))
            (setq a1 (getpoint "\nEnter first alignment point...")
                  a2 (getpoint "\nEnter second alignment point...")
                  a3 (cons (car p) a1)
                  a4 (cons (car q) a2)
                  n1 (subst a3 p a)
                  n2 (subst a4 q n1))
        (cond ((= j1 "L")  (setq n (subst '(72 . 0) j n1))
                           (setq n (subst '(73 . 0) j2 n)))
              ((= j1 "C")  (setq n (subst '(72 . 1) j n1))
              ((= j1 "R")  (setq n (subst '(72 . 2) j n1))
              ((= j1 "A")  (setq n (subst '(72 . 3) j n2))
              ((= j1 "M")  (setq n (subst '(72 . 4) j n1))
              ((= j1 "F")  (setq n (subst '(72 . 5) j n2))
              ((= j1 "BL") (setq n (subst '(72 . 0) j n1))
                           (setq n (subst '(73 . 1) j2 n)))
              ((= j1 "BC") (setq n (subst '(72 . 1) j n1))
              ((= j1 "BR") (setq n (subst '(72 . 2) j n1))
              ((= j1 "ML") (setq n (subst '(72 . 0) j n1))
                           (setq n (subst '(73 . 2) j2 n)))
              ((= j1 "MC") (setq n (subst '(72 . 1) j n1))
              ((= j1 "MR") (setq n (subst '(72 . 2) j n1))
              ((= j1 "TL") (setq n (subst '(72 . 0) j n1))
                           (setq n (subst '(73 . 3) j2 n)))
              ((= j1 "TC") (setq n (subst '(72 . 1) j n1))
              ((= j1 "TR") (setq n (subst '(72 . 2) j n1))
        (entmod n)
   (setq index (+ index 1))
 (prin1)
 (princ "    Changed ")                ; Print total lines changed
 (princ index)
 (princ " text lines.")
 (terpri)
nevermind i figured it out myself :)
this piece of code gave the justify codes for a positions
so i looked up in the auto count tool for something similar and found this
        '(71 . 0)
        '(72 . 1)
        '(73 . 2)
i changed this to
        '(71 . 0)
        '(72 . 0)
        '(73 . 0)
and i got me justify on bottom left :)
i hope this piece of info helps others, cheers all.
readded
(defun c:num  (/ tmpVars pt ang sNum*)
 (setq dVars '(sNum eNum inNum Spc Pref Suff tsize Dir))
 (mapcar '(lambda (x y) (or (boundp x) (set x y))) dVars '(1 10 1 1 "" "" 2.5 "X"))
 (setq tmpVars (list (getreal (strcat "\nSpecify Starting Number <" (rtos sNum 2 0) ">: "))
                     (getreal (strcat "\nSpecify Ending Number <" (rtos eNum 2 0) ">: "))
                     (getreal (strcat "\nSpecify Increment <" (rtos inNum 2 0) ">: "))
             (if (=(setq tmppref (getstring (strcat "\nSpecify Prefix <" (if (eq "" Pref) "-None-" Pref) ">: "))) "") Pref tmppref)
                     (if (=(setq tmpsuff (getstring (strcat "\nSpecify Suffix <" (if (eq "" Suff) "-None-" Suff) ">: "))) "") Suff tmpsuff)
             (if (not(setq tmptsize (getreal (strcat "\nSpecify Textsize <" (if (eq nil tsize) "-None-" (rtos tsize)) ">: ")))) tsize tmptsize)
 (initget "X Y")
 (setq tmpVars
     (Make_Text (polar pt ang (* i Spc)) (strcat Pref (rtos sNum* 2 0) Suff) tsize)
 (princ))
(defun Make_Text (pt val tsize)
 (entmake
   (list
     (cons 0 "TEXT")
     (cons 10 pt)
     (cons 62 2)
     (cons 40 tsize)
     (cons 1 val)
     (cons 50 0.0)
     (cons 71 0)
     (cons 72 1)
     (cons 73 2)
     (cons 11 pt))))
and I have added a textsize prompt.
Greetings from Austria - Scrimski
This works great... One question though... What would I type in the prefix and suffix if I want it to be blank?
Another question.... How would I get the numbers, in the vertical Y form, to go from 1 to whatever, from top to bottom rather than bottom to top, as it is doing now?
