double-click for properties and text edit 2008
tomsturch
I've checked previous threads to figure this out and "dcprops" is not an operative command in 2008. Can anyone tell me how to set my variables to get double-click properties with Cntrl Z close and text editing (version 2008 )? Thanks in advance for your help.
Try Tools > Options > User Preferences. Double-click editing or right-click customization...one of the two ought to do it for you.
I think the previous properties screen has been removed from 2008 and is replaced by a "palette" style properties box, which is instigated by the "properties" command. :?
Thanks boys. Is there a speed key to close the properties menu? Control Z is undo now? Thanks.
CTRL+1 toggles Properties off and on.
Default shortcut keys:
Switching between open drawings Ctrl + Tab
Switching between open programs Alt + tab
SHORTCUT KEYS
*CANCEL* (Same as ESC)CTRL+ \
Select All CTRL+A
Snap toggle on/off CTRL+B
Copy CTRL+C
Toggle dynamic UCS CTRL+D
Toggle Isoplanes CTRL+E
Group Selection On/Off CTRL+H
Toggle Coords CTRL+I
Repeats last command CTRL+J
Hyperlink... CTRL+K
Toggle Ortho CTRL+L
Repeats last command CTRL+M
New... CTRL+N
Open... CTRL+O
Plot... CTRL+P
Quits AutoCAD CTRL+Q
Toggle viewports (PS) CTRL+R
Save CTRL+S
Toggles Tablet Mode CTRL+T
Paste CTRL+V
Cut CTRL+X
Redo CTRL+Y
Undo CTRL+Z
Toggles Groups CTRL+SHIFT+A
Copy with Base Point CTRL+SHIFT+C
Toggles display of
palettes with CTRL+SHIFT+H
Quick Properties CTRL+SHIFT+P
Save As... CTRL+SHIFT+S
Paste as Block CTRL+SHIFT+V
Moves to next layout tab
to the left of current CTRL+PAGE UP
to the RIGHT of current CTRL+PAGE DOWN
Clean Screen CTRL+0
Properties CTRL+1
DesignCenter CTRL+2
Tool Palettes Window CTRL+3
Sheet Set Manager CTRL+4
Info Palette CTRL+5
DBCONNECT CTRL+6
Markup Set Manager CTRL+7
QuickCalc CTRL+8
Command Line CTRL+9
Help CTRL+F1
close drawing or app CTRL+F4
Help F1
Open Text window F2
Toggles Object Snap Mode F3
Toggle Isoplane F5
Move between open drawings F6
Grid on/off F7
Toggles Orthogonal Mode F8
Toggles Snap Mode F9
Toggles Polar Mode F10
Toggles Object Snap Track Mode F11
Suppress Dynamic Input F12
Macros Alt+F8
Visual Basic Editor Alt+F11
TEMPORARY OVERRIDE KEYS
help files lists two overrides for some commands,
try both to see which one(s) work for your setup
Toggles Orthogonal Mode SHIFT
Toggle Object Snap Mode SHIFT+A
Toggles Object Snap Mode SHIFT+'
Object Snap Override : Center SHIFT+C
Object Snap Override : Center SHIFT+,
Disable All Snapping and Tracking SHIFT+D
Object Snap Override : Endpoint SHIFT+E
Object Snap Override : Endpoint SHIFT+P
Disable All Snapping and Track SHIFT+L
Object Snap Override : Midpoint SHIFT+M
Object Snap Override : Midpoint SHIFT+V
Toggle Object Snap Tracking SHIFT+Q
Toggle Object Snap Tracking SHIFT+]
Enables Object Snap Enforcement SHIFT+S
Enables Object Snap Enforcement SHIFT+;
Toggle Polar Tracking SHIFT+X
Toggle Polar Tracking SHIFT+.
Toggle UCSDETECT SHIFT+Z
Toggle UCSDETECT SHIFT+/
Windows keys
WINDOWS SHORTCUT KEYS
**WINDOWS SYSTEM KEY COMBINATIONS**
F1: Help
CTRL+ESC: Open Start menu
ALT+TAB: Switch between open programs
ALT+F4: Quit program
SHIFT+DELETE: Delete item permanently
**WINDOWS PROGRAM KEY COMBINATIONS**
CTRL+C: Copy
CTRL+X: Cut
CTRL+V: Paste
CTRL+Z: Undo
CTRL+B: Bold
CTRL+U: Underline
CTRL+I: Italic
**GENERAL KEYBOARD-ONLY COMMANDS**
F1: Starts Windows Help
F10: Activates menu bar options
SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as
right-clicking an object
CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or
press SHIFT+F10 for a context menu)
ALT+DOWN ARROW: Opens a drop-down list box
ALT+TAB: Switch to another running program (hold down the ALT key and then
press the TAB key to view the task-switching window)
SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass
the automatic-run feature
ALT+SPACE: Displays the main window's System menu (from the System menu, you
can restore, move, resize, minimize, maximize, or close the window)
ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child
window's System menu (from the MDI child window's System menu, you can
restore, move, resize, minimize, maximize, or close the child window)
CTRL+TAB: Switch to the next child window of a Multiple Document Interface
(MDI) program
ALT+underlined letter in menu: Opens the menu
ALT+F4: Closes the current window
CTRL+F4: Closes the current Multiple Document Interface (MDI) window
ALT+F6: Switch between multiple windows in the same program (for example, when
the Notepad Find dialog box is displayed, ALT+F6 switches between the Find
dialog box and the main Notepad window)
**SHELL OBJECTS AND GENERAL FOLDER/WINDOWS EXPLORER SHORTCUTS**
For a selected object:
F2: Rename object
F3: Find all files
CTRL+X: Cut
CTRL+C: Copy
CTRL+V: Paste
SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
ALT+ENTER: Open the properties for the selected object
**TO COPY A FILE**
Press and hold down the CTRL key while you drag the file to another folder.
**TO CREATE A SHORTCUT**
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
Back to the top
**GENERAL FOLDER/SHORTCUT CONTROL**
F4: Selects the Go To A Different Folder box and moves down the entries in the
box (if the toolbar is active in Windows Explorer)
F5: Refreshes the current window.
F6: Moves among panes in Windows Explorer
CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
CTRL+Z: Undo the last command
CTRL+A: Select all the items in the current window
BACKSPACE: Switch to the parent folder
SHIFT+click+Close button: For folders, close the current folder plus all parent folders
**WINDOWS EXPLORER TREE CONTROL**
Numeric Keypad *: Expands everything under the current selection
Numeric Keypad +: Expands the current selection
Numeric Keypad -: Collapses the current selection.
RIGHT ARROW: Expands the current selection if it is not expanded, otherwise
goes to the first child
LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes
to the parent
**MICROSOFT WINDOWS KEY**
Windows Logo: Start menu
Windows Logo+R: Run dialog box
Windows Logo+M: Minimize all
SHIFT+Windows Logo+M: Undo minimize all
Windows Logo+F1: Help
Windows Logo+E: Windows Explorer
Windows Logo+F: Find files or folders
Windows Logo+D: Minimizes all open windows and displays the desktop
CTRL+Windows Logo+F: Find computer
CTRL+L Locks session
CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to
the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the
Quick Launch toolbar and the system tray)
Windows Logo+TAB: Cycle through taskbar buttons
Windows Logo+Break: System Properties dialog box
Application key: Displays a shortcut menu for the selected item
**DIALOG BOX KEYBOARD COMMANDS**
TAB: Move to the next control in the dialog box
SHIFT+TAB: Move to the previous control in the dialog box
SPACEBAR: If the current control is a button, this clicks the button. If the
current control is a check box, this toggles the check box. If the current
control is an option, this selects the option.
ENTER: Equivalent to clicking the selected button (the button with the outline)
ESC: Equivalent to clicking the Cancel button
ALT+underlined letter in dialog box item: Move to the corresponding item
These are my faves:
SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin (Use in Outlook to permanently delete email)
