Results 1 to 6 of 6
    Senior Member erona's Avatar
    Architectural
    erona's Discipline Details
    Architect
    Architectural
    AutoCAD 2013
    Feb 2005
    Philippines
    306
    Default find the center of a broken ellipse
    I'm trying to trace a plan where an ellipse was used for the general shape of a room. Since doors were added, the ellipse was broken into splines. Now I want to retrace the original ellipse but don't know where to start or how.
    BTW, the ellipse was drawn at an unknown angle.
    erona
    Full Member shinymathew's Avatar
    AutoCAD 2006
    Jul 2005
    bangalore, india
    89
    put some lines where you expect the quadrants of the ellipse. then extent the pieces. now you get actual the quadrant points of the ellipse. snap the quadrants using osnap - qua. now you have the major and minor axis by joining the quadrants. centre of the ellipse can be snapped even in the broken condition. or give extend command. right click once more. then pick the ends of the pieces. it will extend to form the full ellipse.
    Architectural
    Architect
    Architectural
    AutoCAD 2013
    Feb 2005
    Philippines
    306
    Thanks for the reply.
    This is what I am trying to avoid, guessing. Of course I can assume the quadrant points but I am looking for a way where I can really hit the right spot.
    erona
    Senior Member
    not specified
    Aug 2005
    Manchester, England
    162
    Try this
    1. Set your osnaps to centre and perpendicular
    2. Draw a line from the centre of the ellipse (it should still snap to it)
    3. Draw to the original quadrant of the ellipse (it should snap to perp)
    4. Scale the line by 2 - you now have one of the axes
    5. Repeat the above for the other axes.
    6. Draw the ellipse using "Ellipse axis end"
  5. #5
    AutoCAD 2006
    Jul 2005
    bangalore, india
    89
    give extend command. right click the mouse once more (extra). then pick the ends of the ellipse. it will extend eventhough it is brocken to form a full ellipse. now by snapping to the quadrant points you can make the axes.
  6. #6
    Architectural
    Architect
    Architectural
    AutoCAD 2013
    Feb 2005
    Philippines
    306
    Thanks for the replies.
    Sorry I didn't mention that the quads are no longer there. All that's left were splines. Anyways, I think I kinda figured it out but my process is somewhat i-guesses.
    erona
