Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Super Member
    AutoCAD LT 2009
    Sep 2008
    500
    Default Removing Text from Commands At the Cursor
    Is there anyway to turn off the coordinates and text that sticks to the cursor during commands in 2009LT?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    I think you might be referring to Dynamic Input. There should be a button at the bottom of your screen that toggles it on/off.
    Super Member
    AutoCAD LT 2009
    Sep 2008
    500
    That worked out great, thank you. I'm still fumbling through this new release. I'm now trying to figure out how to edit the size of an existing text string. I can't seem to locate a properties button that has a window that allows you to type in a new height for text like in the older versions. I tried customizing the toolbars, but the properties tool doesn't alow this.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    Are we talking single line text or multiline text?
  5. #5
    Super Member MaxwellEdison's Avatar
    MaxwellEdison's Computer Details
    XP Pro (32-bit)
    Dell Precision PWS490
    Intel Xeon 5130
    4GB DDR2
    nVidea Quadro FX 3500
    Dell 20" LCD Widescreen (Main) NEC Accusync 125F 20" CRT (Secondary)
    Architecture 2009
    Dec 2008
    Lebanon, PA
    734
    If you're talking about the Properties Palette, Ctrl+1 will open/close it. I can still be docked and moved as in previous releases, at least until the ribbon kills that too
    Just because you're , doesn't mean wrong is all that's .
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    I skipped 2006 but I have used 2004. If you're using multiline text try double clicking on it to bring up the text formatting window. Highlight the text that you want to change the height of then go to the Text Height window and change the setting. Click OK. Does that work?
    To bring up the Properties box select the text then right-click. Properties should be at the bottom of the list. Does that do it for you?
  7. #7
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    Education
    Car5858's Discipline Details
    Maint. Mech.
    Education
    Tutor, lab assisant
    AutoCAD 2010
    May 2009
    Hammond
    371
    I do sugest that you open the properties as Max stated then dock the pallet.
    You can also select the text>right click>menu toward the bottom is properties, left click on properties, dialog box should open.
  8. #8
    Super Member
    AutoCAD LT 2009
    Sep 2008
    500
    Single line text so far. I just figured it out with the properties tool at the top of the screen. My problem is it doesn't show what the tools are when I pass the cursor over them. Only the tools at the bottom do that. Snap mode, ortho, etc. Is there a way to turn that function on?
    By the way, I really appreciate the help.
    Wow, I just read all the replies. Thanks to all. Give me a chance to play with it and see. I now know of the properties dialog box. You folks are great. I'm old school cad and this is a lot to digest.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    Check on the TOOLTIPS system variable (see AutoCAD Help). I think that's one of the things you're looking for.
  10. #10
    Super Member
    AutoCAD LT 2009
    Sep 2008
    500
    Boy you're good. That did the trick.
    Two other things:
    1. I drew a rectangle and did the hatch command. Simply put, I picked the pattern and clicked in the rectangle. When I do this I get above the command line "Analyzing The Selected Data". This seems to take about 30 seconds before I can finish the command. I played with the settings, but it didn't change that.
    2. I have a drawing from a customer with existing single line text, and when I double click on the text, I get a "Text Formatting" window, which is fine. When I type in new text of my own and double click on the text string it just highlights it with no "Text Formatting" window. JUst curious about this one, I can still edit it either way.
  1. Removing Raised Text on a Solid Model
    By skipsophrenic in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Apr 2009, 02:25 pm
  2. Removing an attribute globally
    By bds808 in forum AutoCAD General
    Last Post: 21st Jan 2009, 12:08 am
  3. Problems Removing CAD
    By happyjack87 in forum AutoCAD Beginners' Area
    Last Post: 15th Aug 2008, 03:37 am
  4. removing unfound xrefs
    By Figment in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Apr 2008, 01:01 pm
  5. Removing Portion of a Contour Map
    By skipo4us in forum AutoCAD Drawing Management & Output
    Last Post: 14th Mar 2008, 09:59 pm
