Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    VALAH
    Default OPEN / SAVE / NEW DIALOG BOX MISSING
    Dear fellows,
    In AutoCad 2006, when I want to open a new or existing drawing or template, instead of regular dialog box I receive only a prompter dialog which is present in the command line also, asking me for the name of the drawing that I want to open; it is the case also when I want to save a drawing too. I already checked the "Options" under the "Open and Save" tab and everything looks to be in order. How can I resolve this bothering problem since I am able to perform the above tasks only accessing "Windows explorer"?
    Thank you for your understanding.
    Best regards,
    VALAH
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 7 Home Premium (H)
    Lenovo ThinkStation D20 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Xeon E5503 (W)/AMD Athlon 2 X4 (H)
    4 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Quadro FX 580 (W)/nVidia GF GT430 (H)
    500 GB HDD (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Dell 22" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management
    AutoCAD 2013
    Sep 2002
    Winston-Salem, NC - USA
    4,507
    type "FILEDIA" and change it's setting. It will be on either 1 or 0. Change it to the other and see if that helps.
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
    Senior Member Dommy2Hotty's Avatar
    AutoCAD 2007
    Mar 2004
    Homer Glen, IL
    350
    FILEDIA is the correct variable. Should be turned on to get the dialog. 1 = ON, 0 = OFF.
    Also, if you're faced with that, the ~ will force the dialog so you can finish the open command and then turn filedia on. Here's a quick look:
    Code:
    Command: FILEDIA
    Enter new value for FILEDIA <0>&#58; 1
    Command&#58; OPEN
    //^---Open dialog shows
    Command&#58; FILEDIA
    Enter new value for FILEDIA <1>&#58; 0
    Command&#58; OPEN
    Enter name of drawing to open
    <D&#58;\ASE\RAFB\0429_GAI3B-TT457\A1-4-TT457-PLAN.dwg>&#58; ~
    //^---entering the ~ for the file name will force the dialog so you can finish the command
    AutoCAD 2005
    ADT 2005
    Forum Newbie
    murtazachd's Computer Details
    Windows 7
    AutoCAD 2007
    Jun 2009
    Holly Makkah
    6
    Thanks it is realy helpful
  5. #5
    Forum Newbie ZWCAD's Avatar
    AutoCAD 2012
    Feb 2011
    China
    7
    controls the display of dialog boxes used with commands that read and write files. For example, if FILEDIA is set to 1, saveas displays the Save Drawing As dialog box. If FILEDIA is set to 0, SAVEAS displays prompts on the command line. The procedures in this documentation assume that FILEDIA is set to 1. Even when FILEDIA is set to 0, you can display a file dialog box by entering a tilde (~) at the first prompt.
  6. #6
    Junior Member
    mjavy7's Computer Details
    Win7 Pro 64-bit
    HP-Z200
    HP
    3GHz
    4.00GB
    HD LE2201w
    AutoCAD 2011
    Dec 2007
    Palm River Point, Florida
    19
    It worked for me too! :-)
  7. #7
    Super Member
    designerstuart's Computer Details
    xp
    various
    Architectural
    designerstuart's Discipline Details
    architect
    Architectural
    ADT 2009
    Jun 2010
    near london, near europe
    765
    FILEDIA, PICKADD and PICKFIRST seem to be the route of many curious problems..... but how come they get changed when the OP has never heard of them?
  8. #8
    Super Member DANIEL's Avatar
    Mechanical
    DANIEL's Discipline Details
    Industrial
    Mechanical
    AutoCAD 2013
    May 2005
    Arlington Texas
    1,001
    Quote Originally Posted by designerstuart View Post
    thats a good question
    If you would like to help my 2 year old niece Alaina in her battle against Leukemia you can donate blood at any Carter Blood Care and put SPON050875 on the donor form. Thank you so much for any contributions in this matter that you can make.
    Luminous beings are we, not this crude matter.
  9. #9
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,475
    They can be changed by poorly written lisp routines that fail to reset system variables upon completing whatever task they were designed to do.
  10. #10
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,199
    Third party apps and even AutoCAD commands that are not set up to restore Variables to their previous settings when cancelled.
