Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
  1. #11
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Also check cmddia whenever filedia is inadvertently changed as it is often not reset as well.
  2. #12
    Super Member DANIEL's Avatar
    Mechanical
    DANIEL's Discipline Details
    Industrial
    Mechanical
    AutoCAD 2013
    May 2005
    Arlington Texas
    1,005
    that makes sense, the ol i canceled a command and lost all my osnap settings thing.
    If you would like to help my 2 year old niece Alaina in her battle against Leukemia you can donate blood at any Carter Blood Care and put SPON050875 on the donor form. Thank you so much for any contributions in this matter that you can make.
    Luminous beings are we, not this crude matter.
  3. #13
    Forum Newbie
    AutoCAD 2011
    Jan 2012
    Albuquerque New Mexico
    1
    Thank You. That did the trick. I couldn't find the command to turn it on anywhere.
  4. #14
    Junior Member
    barefootbob's Computer Details
    Mac and PC - Lion / Windows 7
    Civil 3D 2012
    Feb 2012
    Chicago
    11
    Awesome, thanks for the tips.
  5. #15
    Forum Newbie
    Mechanical 2010
    Mar 2012
    3
    that was a relief bless you dear
  6. #16
    Forum Newbie
    AutoCAD 2010
    Apr 2012
    4
    Hello,
    AutoCAD MEP 2010. I have set attdia,filedia and cmddia all to 1. My dialogue boxes will still not come up when I type on the command line. For example, I type "xref" and I get prompts in the command line versus the dialogue box popping up. The same for "layer" and "linetype". Oh and my ~ response to the first prompt does not bring up the dialogue box either.
    I saw in ACAD help that this may be related to AutoLISP. However, I know nothing about AutoLISP. Any help would be greatly appreciated.
  7. #17
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Close AutoCAD, then restart with a different profile or new profile. Does it work now?
    Start AutoCAD with a new profile (copy the shortcut on the desktop, right click on shortcut, go to Shortcut tab, in the Target line after the first statement in quotes you may have a /p profile_name, over write that if it is there with /p newprofile (pick any name that doesn't already exist in your profile folder), and if you don't have a /p profile_name then simply add the /p newprofile to that line. Pick ok, then double click on the icon, AutoCAD will start with the new clean profile, open a drawing and see if you have the same trouble.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  8. #18
    Forum Newbie
    AutoCAD 2010
    Apr 2012
    4
    Ok I was able to do that, it made a new profile. I made sure all of the variables were set to 1. The problem is still there.
  9. #19
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    Do you use more than one monitor?
  10. #20
    Forum Newbie
    AutoCAD 2010
    Apr 2012
    4
    Yes, I have two monitors. However, the prompts continue to come up in the command line [?/Bind/Detach/Path/Unload/Reload/Overlay/Attach] so I don't think that I have a missing window, but maybe.
