Publish Error From SSM: "ERROR: Layout Not Found"
Tallie
Hi Guys,
Just wondering if anyone else has the same issue sometimes that when they try to publish some drawings from sheet set manager only some drawings print and the rest come up with the error : "ERROR: Layout Not Found".
I know that one way to fix this problem is to copy everything either into a new layout or a new drawing, but I was wondering if anyone out there had a better solution to my problem.
Cheers:)
My drawings aren't in model space, so that can't be the problem.
But I did find that removing from them from the sheet set manager and then importing them back in again worked.
I'm just worried that this wont always work.:geek:
