well, there is nothing in AutoCAD where you can hit a button and get a good-looking drawing (it would be awesome though..)
What you can do is use the Layer system to On/Thaw and Off/Freeze certain layers on certain plots/in certain viewports. You can use the Freeze in Viewport alternative in the Layer Manager to have a different look in different viewports on the same drawing.
I see that you are using AutoCAD 2009 - then you can use Annotative text to have texted displayed only in certain scales, that takes some setting up though to make it work properly, but worth it in the end.
