Jhun Gonzalo Posted July 1, 2009 Share Posted July 1, 2009 Hi all, Please to help me to provide a multi-offset Lsp route, this route will select 1 or 2 lines and then pick the reference point other side of the line/pline or pick on mid between selected 2 lines then offset by 50mm, and it automatically change the line to hidden, see attached image what would be look like, Many thanks to all, Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 1, 2009 Share Posted July 1, 2009 I tried a different approach (defun c:off (/ lt off ln1 ln2 pt Objlst) (vl-load-com) (setq lt "HIDDEN") ;; <<--- Destination Linetype (setq off 50.) ;; <<--- Offset (setq objlst '()) (if (and (setq ln1 (car (entsel "\nSelect line 1: "))) (setq ln2 (car (entsel "\nSelect line 2: "))) (vl-every (function (lambda (x) (vl-position x '("LINE" "LWPOLYLINE" "POLYLINE")))) (mapcar (function (lambda (x) (cdr (assoc 0 (entget x))))) (list ln1 ln2))) (setq pt (getpoint "\nSelect Reference Point: ")) [color=Red][b](setq pt (trans pt 1 0)))[/b][/color] (foreach Obj (mapcar 'vlax-ename->vla-object (list ln1 ln2)) (repeat 2 (setq Objlst (append (vlax-safearray->list (vlax-variant-value (vla-offset Obj (setq off (* off -1.))))) Objlst))) (mapcar (function (lambda (x) (vla-put-linetype x lt))) Objlst) (vla-delete (car (vl-sort Objlst (function (lambda (x y) (< (distance pt (vlax-curve-getClosestPointto x pt)) (distance pt (vlax-curve-getClosestPointto y pt)))))))) (setq Objlst '()))) (princ)) Quote Link to comment Share on other sites More sharing options...
Jhun Gonzalo Posted July 1, 2009 Author Share Posted July 1, 2009 Thanks Lee, Very fast creating codes:lol: only one thing i have a problem on UCS, i'm trying to modify and add a TRANS code but it does'nt work, Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 1, 2009 Share Posted July 1, 2009 See the code above, I have updated it hopefully to include UCS compatibility... Quote Link to comment Share on other sites More sharing options...
Jhun Gonzalo Posted July 1, 2009 Author Share Posted July 1, 2009 It work, solved Thanks Lee, Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 1, 2009 Share Posted July 1, 2009 It work, solved Thanks Lee, No probs Quote Link to comment Share on other sites More sharing options...
