Results 1 to 9 of 9
    Forum Newbie
    not applicable
    Jul 2009
    1
    Default How to delete text in a PDF document?
    Hello guys,
    I need to delete text in a PDF document. How can I do it?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I believe you would need a PDF editor of some type.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Do you have access to Adobe Acrobat?
    I thought I read of a way to highlight and copy text in a PDF document and bring it into Microsoft Word for editing but I can't seem to locate the source at this time.
    Where did this text originate from?
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,313
    You can use Photoshop to remove the text, or Print it out and paint over the text with whiteout and then scan it back in. I guess it depends on how much text you need to remove?
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  5. #5
    Senior Member ammobake's Avatar
    ammobake's Computer Details
    Windows 7 Pro 64bit
    HP 2240 SFF Workstation
    HP
    Intel Xeon CPU E3-1225 v5 @ 3.30ghz, 3.30ghz
    18 GB RAM
    Nvidia NVS 510
    Confidential
    Confidential
    4 total (2 - 27 in monitors below, 2- 22 in monitors on top)
    Construction
    ammobake's Discipline Details
    CAD Drafting & Architecutural Design (gov/military)
    Construction
    AutoCAD 2017
    Mar 2008
    Fairbanks, Alaska
    206
    Since you are using autocad 2010, you can turn off certain layers in the original PDF file. You would need to insert the PDF in 2010 as a "PDF UNDERLAY", select the inserted image, right click, and select "PDF LAYERS". For instance, you might be able to turn off text if you needed to (if it isn't correct or something). You could then add in callouts and text OVER the pdf underlay in autocad.
    That's one option.
    To actually edit the original PDF text you would need adobe acrobat though. Adobe reader will do you no good in editing the original text of the document.
    Another possibility would be to insert the PDF as a pdf underlay in autocad, right click, select "PDF CLIP", and you could probably clip off certain things you don't want shown.. Then, with autocad, you could add in the callouts and text you do want to show.
    -ChriS
  6. #6
    Forum Newbie
    AutoCAD 2008
    Jan 2010
    1
    Adobe Acrobat can make it, however, it is too expensive and out of my budget. It cost hundreds of dollars.
    Or you can convert the PDF to Word document with AnyBizSoft, so that you can add or delete anything as you wish in Word.
    I'm using Microsoft Word 2007, so I can save as PDF again easily.
  7. #7
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    Save the *.pdf to a *.jpg and erase the text? Or, paint it the same as the background color?
    I have Adobe Pro, and can edit text if the *.pdf file isn't a scan.
    Same goes for *.pdf drawings, if created in AutoCAD, the *.pdf can be converted into a *.dxf file which you can edit in AutoCAD.
    Not a great solution but, does work.
    Adobe Pro also has a snapshot tool. Great for copy to clipboard and paste into cad, email, or any document. Image below is a "snapshot" from a *.pdf.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  8. #8
    Forum Newbie
    AutoCAD 2010
    Jan 2010
    Cambridge, MA
    4
    I would use Adobe Illustrator. All text and objects are editable usually.
  9. #9
    Forum Newbie
    AutoCAD 2011
    Oct 2011
    4
    Default what type of your pdf file
    There is no more background info in original question that which kind of the PDF file is, text-based or images-based. Two situations below:
    If the text of the PDF file can be searched or copied, then you can convert it to word 2007 in order to remove text. Then save as a new pdf file easily.
    If the text isn’t independent existed, then you need to use OCR program and delete text from PDF after the text has been recognized. You can export the text to word to edit or use a PDF editor either.
  1. I can't delete line using delete and backspace keys
    By alif in forum AutoCAD Beginners' Area
    Last Post: 21st Apr 2009, 03:42 am
  2. Delete layers that wont delete
    By seashell2day in forum AutoCAD General
    Last Post: 31st Mar 2009, 02:38 pm
  3. Can't Delete Text
    By ziemerd in forum AutoCAD Beginners' Area
    Last Post: 13th Nov 2008, 05:00 pm
  4. XML-document - que?
    By Tiger in forum AutoCAD Drawing Management & Output
    Last Post: 11th Mar 2008, 03:32 pm
  5. delete and text edit not working?
    By dirtlegg in forum AutoCAD Drawing Management & Output
    Last Post: 31st Aug 2007, 02:54 am
