Results 1 to 5 of 5
    Senior Member
    BIGMIKE09281946's Computer Details
    XP
    DELL Inspiron 518 & DELL Dimension 8400
    Both PCs have 2MB
    the DELL has 360MB
    I have three flatscreen monitors
    AutoCAD 2010
    Jun 2008
    I am in Southeastern Pennsylvania just west of Philadelphia
    220
    Default Plotting Traverses
    In my Penn Foster text Civil Drafting text there is mention that a bearing of N25dE and a bearing of S25dW have the same angle. While meanwhile the 1st example the text shows they are using degrees and minutes to show the angles.
    I made a drawing of the example, plotting it from left to right, and after figuring out how to correctly dimension the angles as shown came up with different angles. I am trying to do it in reverse order and am unable to do so because I cannot confirm that the opposite of N101d18' is S101d18'.
    Is there a calculator out there I can use?
    I've got nothing to say!
    Super Member
    AutoCAD not applicable
    Jul 2007
    639
    Sorry Bigmike,
    I can't help at the moment, but you might want to warn people that
    this drawing is from an student educational version.
    If I get some free time, I'll take another look.
    If at first you don't succeed, then maybe failure is more your style.
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,969
    Quote Originally Posted by BIGMIKE09281946 View Post
    These two angles are lacking a final direction letter (E or W).
    I am glad that the UK system of angle bearings is the whole circle one where letters are not needed.
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    Education
    Car5858's Discipline Details
    Maint. Mech.
    Education
    Tutor, lab assisant
    AutoCAD 2010
    May 2009
    Hammond
    371
    Is this figure 22-19?
  5. #5
    Super Member
    AutoCAD pre 2000
    Nov 2008
    578
    I don't know what is in the book, nor the example, but take it from a Land Surveyor of more that 30 years the notation you cited are of two different bearings.
    You START at a point, then go NE one direction, or you start at same point and go SW the direction. The resulting line may look to be 180 degrees from one another in appearances, but NOT on the ground. This is an old trick in order to confuse real estate agents and neophytes into thinking they have to then hire a land surveyor or engineer to sort things out. I have been to court and argued this out many times and they are in actuality two different bearings having same point of beginning. In northern states they tend to ike to show off bearings ahving a N in course. In SE states, they tend to like to show of on a plat the bearings having a S in the course. This changes the direction of movement and deed calls over same piece of property.
    In your situation the NE and the SW have nothing to do with fineness or accuracy to direction.
    Wm.
  1. PDF Plotting
    By Rhayes in forum AutoCAD General
    Last Post: 1st Oct 2008, 10:54 pm
  2. Plotting
    By TRS in forum AutoCAD General
    Last Post: 20th Feb 2007, 03:54 pm
  3. Plotting help?
    By jfruscione in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jan 2007, 04:18 pm
  4. plotting help
    By sublimefan86 in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2007, 07:19 pm
  5. PLOTTING
    By LESLIE2050 in forum AutoCAD Beginners' Area
    Last Post: 30th Sep 2005, 05:15 pm
