Suppressing New Project Dialog box in Autocad
santh
Hi
I am using VBA to create new Autocad Project, i dont want to have the new project dialog box. the project name and project path should be given through VBA. so how to suppress the autocad dialog box.
Thanks
  • 2 weeks later...
Why do you need to do this in VBA? :unsure:
Just go to the 'File' menu and select 'New', or type NEW at the command line, and then choose a drawing template.
Then save to the correct file directory with a filename of your choosing.
