I don't know about a LISP, but I often recommend the EATTEXT command. It will capture the text and its coordinates exportable to excel.
Does this help?
Greetings,
I have a 2D site plan with hundreds of elevation numbers (text elements) scattered all around it. What I want to do is run a script that will read what those bits of text say (like "1173.08", etc.) and paste that value into the Z position of the text element, so that the number actually is what it says it is.
Is there an AutoLisp routine that can do this?
Thanks!
-Geoff
Does this help?
Search here its under co-ord pts couple of different lisp routines to do exactly what you want
Anway here is one soloutionCode:; converts text to a point with xyz ; z value equal to text ; by Alan H Nov 99 (while (not (setq ss (ssget)))) (command "layer" "new" "txthts" "") (setvar "clayer" "txthts") (setvar "pdsize" 3) (setvar "pdmode" 35) (while (setq en (ssname ss 0)) ; Entity type (setq entyp (cdr (assoc 0 (entget en)))) (if (= entyp "TEXT") (progn (setq xyz (cdr (assoc 10 (entget en)))) (setq txtht (cdr (assoc 1 (entget en)))) (setq txtz (atof txtht)) (setq ptxyz (list (car xyz)(cadr xyz) txtz)) (command "point" ptxyz) ) ) ; Delete each measured entity from set (ssdel en ss) ;end while )
