Batch Convertpstyles
Jhun Gonzalo
Hi to all,
Good day, I have some question about "convertpstyles", because i have +100 sheets drawings that created on release 14, the print style are not applicalbe to higher version so i will convert the plot style by "convertpstyle" all the drawings 1 by 1, is there any easiest way like BATCH CONVERTPSTYLES that will select all drawings files to convert the plot stye all the drawings. Please help me on this:oops:
Many thanks
Yes Remark,
STB to CTB, script are ok Mark, i already set it on script if you have another options i'll try it also
Many Thanks:)
No other suggestion at this time. I was just following up with you. I had to take some time off over the past couple of days so I wasn't sure where things had left off. That's all.
