Change Existing Text to Number?
AQucsaiJr
I have existing text in my drawing that has already been lined up the way it should exist. Anyone know of a way to just click on the text an have it auto overwrite each test with incrementing numbers...
For instance if I have 10 individual lines of text that all read "example text" and I wanted to change them all to 1 to 10 respectively.
I have been through the majority of the Auto-Numbering LISP files on the forum and, unless I missed it, I can not find one that does this.
Well I guess now is as good a time as any to register at the swamp... I will be able to try this link once registered.
Is this what you're looking for?
Another cool tool from ASMI.
;;  RENUM.LSP - This program converts TEXT, MTEXT and ATTRIBUTES in     ;;
;;              numbers with a prefix and a suffix.                     ;;
;;  Command(s) to call: RENUM                                           ;;
;;  Specify a suffix, a prefix and starting number (for erase the old   ;;
;;  suffix or prefix you should press Spacebar). Pick to TEXT, MTEXT    ;;
;;  ATTRIBUTES or press Esc to quit. The program remembers old          ;;
;;  properties and it is possible to confirm it pressing of Spacebar    ;;
;;  key.        ;;
;;  THIS PROGRAM AND PARTS OF IT MAY REPRODUCED BY ANY METHOD ON ANY    ;;
;;  MEDIUM FOR ANY REASON. YOU CAN USE OR MODIFY THIS PROGRAM OR        ;;
;;  PARTS OF IT ABSOLUTELY FREE.                                        ;;
;;  THIS PROGRAM PROVIDES 'AS IS' WITH ALL FAULTS AND SPECIFICALLY      ;;
;;  DISCLAIMS ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS        ;;
;;  FOR A PARTICULAR USE.                                               ;;
;;  V1.0, 16 June, 2005, Riga, Latvia                                   ;;
;;  © Aleksandr Smirnov (ASMI)                                          ;;
;;  For AutoCAD 2000 - 2008 (isn't tested in a next versions)           ;;
;;                             http://www.asmitools.com                 ;;
(defun c:renum (/ oldPref oldSuf oldStart curText curStr)
 (vl-load-com)
 (if(not rnm:Pref)(setq rnm:Pref ""))
 (if(not rnm:Suf)(setq rnm:Suf ""))
 (if(not rnm:Start)(setq rnm:Start 1))
 (setq oldPref rnm:Pref
       oldSuf rnm:Suf
       oldStart rnm:Start); end setq
 (setq rnm:Pref
   (getstring T
     (strcat "\nPrefix: <"rnm:Pref">: ")))
 (if(= "" rnm:Pref)(setq rnm:Pref oldPref))
 (if(= " " rnm:Pref)(setq rnm:Pref ""))
 (setq rnm:Suf
   (getstring T
     (strcat "\nSuffix: <"rnm:Suf">: ")))
 (if(= "" rnm:Suf)(setq rnm:Suf oldSuf))
 (if(= " " rnm:Suf)(setq rnm:Suf ""))
 (setq rnm:Start
   (getint
     (strcat "\nStarting number <"
        (itoa rnm:Start)">: ")))
 (if(null rnm:Start)(setq rnm:Start oldStart))
    (while T
      (setq curStr(strcat rnm:Pref(itoa rnm:Start)rnm:Suf))
        (setq curText
          (car
            (nentsel "\n<<< Pick TEXT, MTEXT or ATTRIBUTE or press Esc to quit >>> ")))
      (if
        (and
          curText
          (member(cdr(assoc 0(entget curText))) '("TEXT" "MTEXT" "ATTRIB"))
          ); end and
        (vla-put-TextString
          (vlax-ename->vla-object curText)curStr)
           (setq rnm:Start(1+ rnm:Start))
        ); end progn
       (princ "\n This is not DText or MText ")
       ); end if
      ); end while
 ); end of c:renum
(princ "\n[info] http:\\\\www.AsmiTools.com [info]")
(princ "\n[info] Renumber tool. Type RENUM to run. [info]")
do a find and replace. works very well from autocad 2005 onwards.
Even with incrementing numbers?
Also, just thought - my program (AutoNum V4), has a replacement option, which will do what you want - can't believe i forgot about that! :oops:
