Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Junior Member
    AutoCAD 2000
    Jul 2009
    13
    Default lines (bearing/distance)
    autodesk map
    i dont know much about cad.
    I need to create 4 lines with different bearing and distance. when i create the lines they run to the left with no end point. how do i get these lines to connect.
    line 1 @2639.77<s89dw
    line 2 @211.11<N85dw
    line 3 @2641.02<n88dw
    line 4 @2638.88<n88d30'w
    i am trying to get them to connect so i can get mean bearing.
    any help to find the mean would help also.
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,557
    Take a look at this:
    http://www.cadtutor.net/tutorials/au...urvey-data.php
    Make sure your running object snaps are OFF.
    R.K. McSwain
    CAD Panacea | twitter
    Junior Member
    AutoCAD 2000
    Jul 2009
    13
    i cant get the lines to stop it just keep going no end points. any help
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    Car5858's Discipline Details
    retired, disibality
    See details below.
    Tutor, AMA glider competitions.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Increase your drawing limits. Make sure you have Surveyor's units set.
    Draw the line's
  5. #5
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    If a line or any other geometry runs out of the screen, enter in the command line Z E
    That will inform AutoCAD that you wish to Zoom to Extents of the drawing. Notice the space after Z and after E -they act like <Enter>
    Just a question: are you using real lines, or construction lines? Because the construction lines are infinite.
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,133
    Assuming that there is a typo in the first angle, (s89dw should be N89dW), then the mean angle is the average of the angles which is 87.625, so the mean bearing is N87.625dW
  7. #7
    Junior Member
    AutoCAD 2000
    Jul 2009
    13
    Quote Originally Posted by eldon View Post
    no it is s89dw
    mean bearing is N89-03-30W
  8. #8
    Junior Member
    AutoCAD 2000
    Jul 2009
    13
    Quote Originally Posted by fuccaro View Post
    using lines
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,133
    Quote Originally Posted by cordgrass View Post
    no it is s89dw
    Ok, I am unused to working in those units, but having more time now, I am unable to arrive at your solution.
  10. #10
    Junior Member
    AutoCAD 2000
    Jul 2009
    13
    A guy i work with showed me how to get N89-03-30W
    ill attach the drawing
    i put in the 4 lines with bearing distance then. then ran a line from e endpoint to the west endpoint.
  1. Draw line in the mid distance of 2 existing lines
    By motee-z in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jul 2016, 10:02 am
  2. Lisp routine for the perpendicular distance between two lines
    By bsimpson in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Nov 2008, 05:08 pm
  3. Minimum distance between non-coplanar lines crossing over each other
    By asalameh in forum AutoCAD Drawing Management & Output
    Last Post: 28th Apr 2007, 12:52 am
  4. calculate distance between two lines thru lisp
    By vivekgrs in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Jul 2006, 12:18 pm
  5. Distance between two lines
    By undoman in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jun 2006, 06:58 am
