Jozi68 Posted July 16, 2009 Share Posted July 16, 2009 Hi All, I'm using vb.net to write a DLL that I can load with netload. How can I set the drawing's UCS to world in VB? All suggestions are appreciated. Jozi68 Quote Link to comment Share on other sites More sharing options...
Jozi68 Posted July 23, 2009 Author Share Posted July 23, 2009 I would also like to change UCSFollow to 0. Anyone? Quote Link to comment Share on other sites More sharing options...
Jozi68 Posted September 21, 2009 Author Share Posted September 21, 2009 I have heard there is a way to send a command to your drawing. Perhaps something like that could work? Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 21, 2009 Share Posted September 21, 2009 Coordinate systems are associated with viewports. So, if a viewport were aquired (via a transaction with Editor.ActiveViewportId, perhaps) then it’s coordinate system could be changed with Viewport.SetUcsToWorld. Quote Link to comment Share on other sites More sharing options...
Jozi68 Posted September 21, 2009 Author Share Posted September 21, 2009 I am not using viewports at the moment, but not all drawings are set to ucs world. Surely there should be a way to change a drawing to ucs world (while in model)? Quote Link to comment Share on other sites More sharing options...
gile Posted September 21, 2009 Share Posted September 21, 2009 Hi, This sould work for the current viewport (C# code, I let you translate) Editor ed = Application.DocumentManager.MdiActiveDocument.Editor; ed.CurrentUserCoordinateSystem = new Matrix3d(new double[16]{ 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0}); Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 21, 2009 Share Posted September 21, 2009 I’ve got to plead guilty to giving bad advice with the Viewport.SetUcsToWorld recommendation. Quite frankly, I can’t find a scenario where that method works as advertised. If it does perform some task, it isn’t what I assumed it would be. Quote Link to comment Share on other sites More sharing options...
Jozi68 Posted September 22, 2009 Author Share Posted September 22, 2009 Thanks gile, it seems to work. Now I just need a way to make sure the user is actually in model (NOT paper). No problem Seant, you've already helped me more than anyone else. Quote Link to comment Share on other sites More sharing options...
