angekap Posted July 16, 2009 Share Posted July 16, 2009 Q: :(hi i have used autocad before in i feel bad to ask this question because is simple but i don´t know how to fix the problem, using autocad map 2007 i found that the boxes with snap,and the other 9 boxes of tools usually located underneath the comand´s line are´t showing in the regular horizontal way but they are shown hiden in the same place but not showing the boxes horisontally, can somebody tell me how to make this interface work normally? thanks a lot angelica Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 16, 2009 Share Posted July 16, 2009 Look in the lower left hand corner of your screen below the command line. Do the coordinates show up? If so, right-click in a blank area to the right of this. A pop up window should appear with a list of the buttons. At the bottom of the list it says Tray Settings. Click on this. In the Tray Settings window enable everything except Display Time. Then click the OK button. Does that do the trick? Your screen is maximized is it not? Quote Link to comment Share on other sites More sharing options...
angekap Posted July 20, 2009 Author Share Posted July 20, 2009 thanks, but it still doesn´t show the settings horizontally, the cordinates show up, and when i click in the black are (an arrow ) it shows other things but not the list of bottons that i want to show and at the bottom of the list it does says tray settings,,,, i appresiate your help Angelica Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 20, 2009 Share Posted July 20, 2009 Are you saying that they do not show up at all or that they show up vertically? Quote Link to comment Share on other sites More sharing options...
angekap Posted July 21, 2009 Author Share Posted July 21, 2009 they show ap vertically, but i guess i fix it because today they look right (horizontally) what i did yesterday was going to the tools menu,then options and on perfil i changed to the original values ,,,,,,thanks for all your help and i´m glad there are forums like this !! see you Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 21, 2009 Share Posted July 21, 2009 Glad to hear you figured it out on your own. Thanks too for updating us with the solution. Quote Link to comment Share on other sites More sharing options...
