Finding Total size of all objects
ARGV
Hello.
I'm looking to, WITHOUT using blocks, find out how big the smallest imaginary square is that would hold all objects in the drawing. (like BOUNDINGBOX property)
I'm not real good with deep down stuff in entity objects, but I know you can find out the vertices of objects by using ENTNEXT a couple times or something. ?? Whats the best way to do this?
thanks.
-ArgV
So your looking for the size of the largest entity in your drawing or trying to find out how big a box would be to contain all of your entities?
Something like this?
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:bigbox [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] xlst ylst ss sel doc MiP MaP pts
                  xlst ylst xmin xmax ymin ymax[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] xlst [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED])[/color][/b] ylst [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED])[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"_X"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]vlax-for[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] sel [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveSelectionSet[/color][/b]
                               [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] doc
                                 [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b]
                                   [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-acad-object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]vla-getBoundingBox[/color][/b] Obj [b][color=DARKRED]'[/color][/b]MiP [b][color=DARKRED]'[/color][/b]MaP[b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pts [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-safearray->list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] MiP MaP[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
             xlst [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]car[/color][/b] pts[b][color=RED])[/color][/b] xlst[b][color=RED])[/color][/b]
             ylst [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] pts[b][color=RED])[/color][/b] ylst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] xmin [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]min[/color][/b] xlst[b][color=RED])[/color][/b] xmax [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]max[/color][/b] xlst[b][color=RED])[/color][/b]
           ymin [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]min[/color][/b] ylst[b][color=RED])[/color][/b] ymax [b][color=RED]([/color][/b][b][color=BLUE]apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]max[/color][/b] ylst[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]vlax-put-property[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]vla-addLightWeightPolyline[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ModelSpace[/color][/b] doc[b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-variant[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]vlax-safearray-fill[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]vlax-make-safearray[/color][/b]
                 [color=Blue][b]vlax-vbdouble[/b][/color] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#009900]7[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] xmin ymin xmin ymax xmax ymax xmax ymin[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=DARKRED]'[/color][/b]Closed [b][color=Blue]:vlax-true[/color][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]vla-delete[/color][/b] sel[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Well, If that compares all bounding box co-ordinates like I think it does, and ends up with just a giant box that encompasses all objects, then yes. :)
Thank you, I'll be using that in a bit. Plus, thanks, now I know how to use the make-safearray function. Wasn't sure how to declare the size of it.
-ArgV
Option #2. What I'm doing is scripting through a bunch of DXF files that, if it is taller than it is wide, then rotate (landscape view) the geometry.
My first idea was just to get all the vertices and find the biggest and smallest, my next idea was the one that is so elegantly done above. I just thought maybe there was another way that might be easier.
But, this'll work just fine I believe.
thanks.
