Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: Splitting Line
    Senior Member StevenMc's Avatar
    AutoCAD 2009
    Mar 2009
    Glasgow
    222
    Default Splitting Line
    hi all,
    could anyone tell me if there is a command to split a line into segments?
    i know there is the divide command but that does not physically split the line, it just gives it points. i need the line to be seperate segments without the gap like the break command gives.
    sorry if i'm not too clear on this, its hard to put into words
    cheers
    Steven
    "Leave it on the doorstep and get the hell outta here!"
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,140
    Didn't someone (Lee Mac?) write a lisp routine that did something similar to this? Sorry, just can't recall for sure. Check around.
    AutoCAD 2009
    Mar 2009
    Glasgow
    222
    thanks ReMark, i have had a search but but cant seem to find it. i'll ask Lee if he has done this previously or maybe he can help me out if he hasnt.
    Senior Member
    MEP 2011
    Jun 2007
    194
    try this one. It seems to work
  5. #5
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Quote Originally Posted by StevenMc View Post
    hi all,
    The ._BREAK command doesn't leave a gap if you break it at a single point. Use the "@" character to specify the second point.
    Command: ._BREAK
    Select object:
    Specify second break point or [First point]: _F
    Specify first break point: <specify point>
    Specify second break point: @
    Command:
  6. #6
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    hi all,
    cheers
    Steven
    The attached may work for what you want. Open the lisp file to see all the various commands available to you. In each case there have to be lines on or crossing the object to use for break points.
    Not one I wrote, author is noted in lisp file.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  7. #7
    Forum Newbie
    AutoCAD 2010
    Nov 2010
    1
    RKMcSwain´s answer worked perfect for me.
    thanks, love you guys out there!
  8. #8
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,791
    Also brillance by Lee Mac
    Code:
    ;;------------------------=={ Segs }==------------------------;;
    ;;  Divides selected objects into an LWPolyline with a        ;;
    ;;  specified number of segments                              ;;
    ;;  Author: Lee McDonnell, 2010                               ;;
    ;;  Copyright © 2010 by Lee McDonnell, All Rights Reserved.   ;;
    ;;  Contact: Lee Mac @ TheSwamp.org, CADTutor.net             ;;
    (defun c:Segs ( / *error* _StartUndo _EndUndo doc ss )
      (vl-load-com)
      ;; © Lee Mac 2010
      (defun *error* ( msg ) (and doc (_EndUndo doc))
            (princ (strcat "\n** Error: " msg " **")))
      (defun _StartUndo ( doc ) (_EndUndo doc)
        (vla-StartUndoMark doc)
      (defun _EndUndo ( doc )
        (if (= 8 (logand 8 (getvar 'UNDOCTL)))
          (vla-EndUndoMark doc)
      (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)) *segs (cond ( *segs ) ( 10 )))
      (if
        (and
          (setq ss (ssget "_:L" '((0 . "ARC,CIRCLE,LWPOLYLINE,SPLINE,LINE,ELLIPSE"))))
          (progn (initget 6)
            (setq *segs (cond ((getint (strcat "\nSpecify Number of Segments <" (itoa *segs) "> : "))) ( *segs )))
          (lambda ( j / e inc i pts ) (_StartUndo doc)
            (while (setq e (ssname ss (setq j (1+ j))))
                (lambda ( inc i / pts )
                  (repeat (1+ *segs)
                    (setq pts (cons (trans (vlax-curve-getPointatDist e (* (setq i (1+ i)) inc)) 0 e) pts))
                  (if
                    (entmake
                      (append
                        (list
                          (cons 0   "LWPOLYLINE")
                          (cons 100 "AcDbEntity")
                          (cons 100 "AcDbPolyline")
                          (cons 90 (length pts))
                          (cons 38 (caddar pts))
                          (cons 70 0)
                        (vl-remove-if 'null
                          (mapcar
                            (function (lambda ( d ) (assoc d (entget e)))) '(6 8 39 48 210)
                        (mapcar (function (lambda ( a ) (cons 10 a))) pts)
                    (entdel e)
                (/ (vlax-curve-getDistatParam e (vlax-curve-getEndParam e)) (float *segs)) -1
            (_EndUndo doc)
          -1
    Super Member Organic's Avatar
    Civil
    Civil 3D 2013
    Feb 2009
    1,641
    Quote Originally Posted by rkent View Post
    This is exactly what I was looking for. This works fine although I am wondering if there is a built in function in AutoCad 2012 or Civil 3D 2012 that does this yet?
  10. #10
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    I don't know about AutoCAD 2012 or Civil 3D, but in Autodesk Inventor the command for splitting a line is called, well, Split....
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  1. Splitting polygons.
    By its.personal in forum AutoCAD General
    Last Post: 24th Jun 2009, 08:09 am
  2. Splitting a Solid in 3ds
    By cadboi08 in forum 3D Modelling
    Last Post: 30th Aug 2008, 07:48 am
  3. Splitting the Autodesk Forum
    By Mr T in forum Feedback
    Last Post: 27th May 2004, 10:05 pm
  4. Splitting Layers?
    By Qwest in forum AutoCAD Drawing Management & Output
    Last Post: 30th Apr 2004, 01:34 pm
