Is the UCS icon on and are you in the World UCS? If yes. is W pointing up? If not the UCS or view may be rotated/twisted. Try listing one of the segments of the boundary with a known bearing.
Hello-
First post and thanks to anyone who can help. I'm good with CAD but by no means a guru.
I am running 2004LD and received a Survey drawing from a client. The drawing has a boundary drawn correctly but when I draw a line by direction, such as N45E, the line goes in a NW'erly direction although it labels as N45E. This is driving me nuts since I have have never had this happen to me before. When in a prototype, everything works fine.
One radian is 57° 17' 45"
Seems like the plan got rotated (that would be a capital offense in some engineering firms). By any chance did an architect have their hands on it?
You could rotate it 1 radian (although rotate > reference might be easier).
I doubt that happened. It's an ALTA survey and all linework is at is should, the UCS is on World with the X point up, but yet lines drawn by direction (and labeled) do not appear correctly. I'm stumped. I'm not sure how to fix this so lines drawn by direction actually go in the proper direction.
Actually the Y on the UCS icon should be pointing up for North to be vertical on the screen. Try the Plan command.
If you want, post the boundary and I'll take a look.
Have you checked ANGBASE ?
