Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    Forum Newbie
    AutoCAD 2004
    Aug 2009
    2
    Default Is there any way to install Express Tools in Vista 64?
    I just got a new computer and it had Vista 64 (I went with 64 because I have 6 gigs of RAM) and when I try to install Express Tools, it gives me an error that this program cannot be installed onto a 64 bit operating system. I know that Express Tools has a 16bit installer, and I guess thats what is causing the problem.
    Does anyone have a suggestion about how I can get Express Tools to work? I really rely a lot on the tools that provides.
    Thank you,
    Tony
    *Vista 64
    *LDD 3
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,582
    How are you installing it? What version of AutoCAD are you running?
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Forum Newbie
    AutoCAD 2004
    Aug 2009
    2
    Quote Originally Posted by StykFacE View Post
    I'm installing it from the original EXE that came with my Land Desktop V3. The exact error message is:
    "Unsupported 16-bit Application
    The program or feature
    "\??\C:\USERS\TONY\APPDATA\LOCAL\TEMP\~EXB0005\SET UP.EXE cannot start or run due to the incompatibility with 64-bit versions of Windows. Please contact the software vendor to ask if a 64-bit Windows compatible version is available."
    Then another box pops up and it says:
    "WinExec failed: return=216"
    Whatcha Think?
    Luminous Being alanjt's Avatar
    Civil 3D 2011
    Apr 2008
    6,050
    copy the express tools folder to the hDD, menuload the express.mnu and appload the lsp files, etc. you might need to add the file location to your support paths.
    i had to this when i switched from 14 to 2002 (didn't come express tools), so i just figured out how to load the bonus tools from 14.
  5. #5
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    8GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    In a nutshell, I create 3D models from the client's CAD files or design sketches, which I then use to produce high quality rendered images. Click on the link in my signature to view my portfolio. I'm always looking for work, so let me know if you need any renders. :)
    3ds Max 2011
    Feb 2006
    Southern California
    8,487
    But Autocad 14 and 2002 are both 32 bit applications, which I assume you were running on a 32 bit system? The OP is trying to install a 32 bit application on a 64 bit system.
    I would do as the message suggests and contact Autodesk.
    "Work Smart, Not Hard"
    Click to View My Portfolio ( Updated 05/21/2013 ) --->
    http://www.rdeweese.com/
  6. #6
    Civil 3D 2011
    Apr 2008
    6,050
    Quote Originally Posted by Cad64 View Post
    right, but this just bypasses the actual installation procedure (what the .exe is doing).
  7. #7
    Forum Newbie
    Architecture 2002
    May 2010
    7
    Was this ever solved? I am having the same problem.
    I am running Windows 7 Professional x64 with AutoCAD 2002.
    When I try to load express tools I get an error WinExec failed: return=216.
    Please HELP!
  8. #8
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,478
    Did you attempt the method suggested earlier in this thread (post #4) by alanjt?
    Keep in mind you already have installed a 32-bit application (AC 2002) in a 64-bit environment so what you are now attempting to do should be feasible. Just have to puzzle out the methodology.
    Now you have discovered one of the drawbacks to keeping older programs running on newer equipment using the latest OS. It isn't always easy. But you wanted a challenge right?
  9. #9
    Forum Newbie
    Architecture 2002
    May 2010
    7
    I don't understand what he is saying. I am new to all of this stuff.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,478
    Quote Originally Posted by dogbytecomputers View Post
    New to computers or new to AutoCAD or both?
    Basically he's saying copy the Express Menu folder to your hard drive.
    Start AutoCAD and use the Menuload command to load the Express menu and Appload command to load the individual Lisp routines associated with the commands.
  1. Autocad 09 install on windows Vista Error
    By shift1313 in forum Software & Licensing
    Last Post: 29th Dec 2010, 06:22 am
  2. Replies: 2
    Last Post: 22nd Feb 2009, 05:43 am
  3. Can't install ACAD 2009 on Vista 64-bit
    By nscherneck in forum AutoCAD General
    Last Post: 31st Aug 2008, 01:08 am
  4. Express Tools
    By GAG in forum AutoCAD General
    Last Post: 14th Nov 2006, 03:31 pm
  5. I want my Express Tools!
    By Steamineagle in forum AutoCAD Beginners' Area
    Last Post: 18th Oct 2006, 06:09 pm
