pedzcabz Posted August 9, 2009 Share Posted August 9, 2009 Anybody can help me about my 3d mesh models,the gizmo icons cannot be seen im my models when i select the add crease icon,so i connot stretch my models.its far different in the tutorials..any idea about this!!!!! Quote Link to comment Share on other sites More sharing options...
kencaz Posted August 9, 2009 Share Posted August 9, 2009 are you holding the Ctrl key while selecting the face you want to stretch. This should bring up the stretch gizmo for that face. KC Quote Link to comment Share on other sites More sharing options...
pedzcabz Posted August 9, 2009 Author Share Posted August 9, 2009 No, im not holding the Ctrl key and even hold ctrl key it is the same result,and it is always asking select subobject to crease. There is some settings on mesh modeling before we start? Thanks in advance for those who throw helpul suggestions!!!! Quote Link to comment Share on other sites More sharing options...
kencaz Posted August 9, 2009 Share Posted August 9, 2009 The subobject would be one of the mesh facets, or an edge. After the crease is in place, that creased portion will remain flat, (if you use the {always} option), even after smoothing. Also, you may want to check your "SELECTIONPREVIEW" and PREVIEWEFFECT variables to make sure your seeing what your attempting to select. Mine is: SELECTIONPREVIEW: [3] Always On PREVIEWEFFECT: [0] Dashed Lines only KC Quote Link to comment Share on other sites More sharing options...
pedzcabz Posted August 9, 2009 Author Share Posted August 9, 2009 I Try to follow this steps but still i cannot see the colored gizmo icons on the models,when i click the object,the gizmo icon is display in the middle but when i click the add crease icon the gizmo is missing in the model thats why i cannot stretch it out. When i click the model after clicking of add crease Thanks Quote Link to comment Share on other sites More sharing options...
pedzcabz Posted August 9, 2009 Author Share Posted August 9, 2009 I want to insert my model view but it does not appear on the message, Can you help on this so that i can show what happen on my models. Thanks again Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 9, 2009 Share Posted August 9, 2009 When i click the model after clicking of add crease How to add images to your posts Quote Link to comment Share on other sites More sharing options...
kencaz Posted August 10, 2009 Share Posted August 10, 2009 when i click the object,the gizmo icon is display in the middle but when i click the add crease icon the gizmo is missing in the model thats why i cannot stretch it out. You are aware that these are separate operations, right? When you are in the crease operation you will not see the gizmo. You need to finish the crease operation by hitting enter. Then select the individual face you want to stretch by holding the Control key and clicking the face. Then the gizmo will appear. KC Quote Link to comment Share on other sites More sharing options...
