kong0781 Posted August 11, 2009 Share Posted August 11, 2009 Hello I am a new user of Autocad and now have a problem with the script. This is my script (command "._insert" "myblock=myblock.dwg" nil) save this command will update the existing block in the drawing with the block that is saved in DWG. the problem is when I run this script. The save command doesnot execute. Actually It stop after"(command "._insert" "myblock=myblock.dwg" nil) " this command. Anybody here know what is the reason? Thank you in advanced K0781 Quote Link to comment Share on other sites More sharing options...
NBC Posted August 11, 2009 Share Posted August 11, 2009 look at how you are using the command to insert your block. you will need to follow a similar syntax in order to perform the command save e.g. (command "qsave") Quote Link to comment Share on other sites More sharing options...
kong0781 Posted August 11, 2009 Author Share Posted August 11, 2009 Thank you for your answer NBC. I changed my script to (command "._insert" "myblock=myblock.dwg" nil) (command "qsave") however It also doesnot work. are there another way to write the script? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 12, 2009 Share Posted August 12, 2009 if your running it as a script you dont need command thats lisp. ._insert myblock=myblock.dwg qsave You need to pay attention to end of lines in a script you need extra spaces to equal "Enter" presses I add blank lines (nothing in them !!!) to give an Enter answer two spaces in between commands can be where you need say press Enter twice. ._insert myblock=myblock.dwg qsave or ._insert myblock=myblock.dwg qsave You need sometimes to write down every key press or whats typed, its like evrything practice makes perfect. Quote Link to comment Share on other sites More sharing options...
