+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Full Member
    Using
    Civil 3D 2008
    Join Date
    Oct 2008
    Location
    Salem, Oregon USA
    Posts
    49
    Default Contour and Surface
    Hello all
    How could I separate contours from a surface. I want to pick each contours separately for editing. At the moment Contours are attached together-as-one!
    thanks
    Jackie
  2. #2
    Senior Member Hardney's Avatar
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    Montreal, Qc
    Posts
    172
    Idea
    Quickly, I would say, make a copy of you surface and explode the copied surface you should have your contours on whatever layers they are on individually. It might take a lot of space though.
    Hardney
    Dying's for the rest of your life.
  3. #3
    Full Member Danse_Macabre's Avatar
    Using
    AutoCAD 2008
    Join Date
    Jun 2009
    Location
    London, Ontario, Canada
    Posts
    56
    Default
    What about the contours do you want to edit? You might be able to acheive what you want to do using breaklines or something like that? I am always extremely hesitant about exploding things, as was said above it will make your drawing bigger and will make it less convenient to use.
  4. #4
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,786
    Default
    You can export out the contour lines they become polylines
    Surfaces utilities extract objects from surface
  5. #5
    Senior Member
    Using
    Civil 3D 2011
    Join Date
    Jul 2008
    Location
    Colorado
    Posts
    247
    Default
    The general concept in Civil 3D is you don't edit the contours, you edit the surface definition.
    You CAN extract contours from a surface, then simply change the contours. But if you simply change the contours without changing the underlying surface, you impact all the other things that you can do with a well-built surface, such as calculating volumes, creating profiles, etc.
  6. #6
    Forum Newbie
    Using
    Civil 3D 2008
    Join Date
    Aug 2009
    Posts
    2
    Default
    Quote Originally Posted by sinc View Post
    That is very well put.
    I know different software need contour or 3d faces but that all can be extracted from the surface to be used as a stand alone dwg.
    my 2 cent.
    Sticks
Similar Threads
  1. surface -> planar surface
    By frunza_samuel in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Jul 2012, 12:20 pm
  2. Corridor/surface contour creation???
    By JerryG in forum Civil 3D & LDD
    Last Post: 23rd Jun 2009, 07:26 pm
  3. Replies: 1
    Last Post: 8th Jun 2009, 12:25 am
  4. Contour labels disappear and surface issues.
    By shoehne in forum Civil 3D & LDD
    Last Post: 13th Jan 2009, 04:42 am
  5. How do I Contour?
    By blkstang87 in forum AutoCAD Beginners' Area
    Last Post: 22nd Sep 2008, 09:44 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
