Results 1 to 7 of 7
    Full Member wsucad's Avatar
    wsucad's Computer Details
    WIN 7
    i7 2.8ghz
    8 GB
    Two 23" Viewsonic Flat Panels
    AutoCAD 2010
    Oct 2006
    Ohio
    57
    Default Rotate a view within a viewport in paperspace without changing the view in model spac
    I want to Rotate a view within a viewport in paperspace without changing the view rotation in model space. Is this possible?
    Currently Using: AutoCAD 2010 and Civil 3D 2013 on a Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz 2.93 GHz with 8GB of RAM on WIN 7 Professional 64bit OS
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,116
    From the AutoCAD 2009 Help file.
    "You can rotate an entire view within a layout viewport by changing the UCS and using the PLAN command."
    Is this what you are referring to?
    WIN 7
    i7 2.8ghz
    8 GB
    AutoCAD 2010
    Oct 2006
    Ohio
    57
    that is exactly what I as looking for. I could not search the help file correctly.
    THANKS!!!
    Dave
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,116
    Also from AutoCAD Help.
    "For a faster method, use the Align and then Rotate View options in the MVSETUP command."
    You're entirely welcomed Dave.
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    DVIEW, TWist is another method although I prefer the UCS and PLAN commands.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  6. #6
    Forum Newbie
    AutoCAD 2009
    Aug 2009
    1
    I would tend to use MVSETUP to this, using the UCS option with the plan rotation is also an effective way but if its simply for a one off view you can avoid the need for creating a new UCS using MV.
  7. #7
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    Just an extra 10 seconds worth when you set your ucs also do a S (save) give it a name then you change any view at will Ucs R name Plan.
    Jump back to world Ucs R World optional "plan"
    Changing your model view makes drawing text easier we then jump back to world when doing true survey co-ords but dont necessarily do a "plan" hope that makes sense.
    Also not limited to one ucs eg Road1 Road2 etc curvey road had 15 ucs's so would align best on sheets.
  1. Rotate a view in a viewport
    By jvwarnick in forum AutoCAD General
    Last Post: 9th Apr 2013, 10:57 am
  2. Rotate The View Within The Viewport
    By ColinDJarvis in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th May 2008, 01:31 pm
  3. Rotate a view in a viewport
    Last Post: 8th Mar 2008, 10:51 pm
  4. rotate view inside viewport
    By Leen in forum AutoCAD General
    Last Post: 10th Apr 2006, 02:03 pm
  5. transfer model view to 2d paperspace
    By erona in forum AutoCAD General
    Last Post: 23rd May 2005, 04:00 am
