Results 1 to 5 of 5
    Super Member Bill Tillman's Avatar
    AutoCAD 2013
    Oct 2008
    Miami, FL
    870
    Default Inventor to AutoCAD 2010
    I have a stubborn engineer who insists on using Inventor, but we use AutoCAD 2010. Can he save a drawing he created with Inventor to a format that can be opened and edited with AutoCAD 2010?
    It's deja vu, all over again.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,093
    I think Inventor drawings can be exported to both DWG and DXF file formats. JDM would know for sure.
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    2,859
    if you are doing sheet metal you can export face as a dxf. (edit, in flat pattern)
    with 3d solids you can save copy as a .sat file and in acad you can use acisin. i cant recall if you can do any direct dwg or dxf file saving in 2010. I doubt it since acad is obsolute since you guys have inventor maybe you should switch over
    edit: you can save a drawing file as a dwg or dxf but these are only 2d files.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
    Super Moderator Lazer's Avatar
    Lazer's Computer Details
    Windows 7
    HP xw 4600 Workstation
    Intel Core2 Duo, 3 Gig
    8GB
    NVIDEA Quadro FX 1700
    1TB
    Portable TB drive
    Samsung SyncMaster 226
    Inventor 2013
    Aug 2005
    Northants, England
    1,565
    If he opens up an .IDW and projects a 2d image from his 3d model in Inventor then he can in Inventor save out as a dwg or dxf for you to open in Autocad this will allow you to edit it as you wish using 2d autocad, if yo need the 3d data in autocad he can do as said above by 'shift1313' and save out as a .sat, then import to autocad, you can edit it but you will only have a dumb solid to play with.
    USING AUTOCAD 2013 AND INVENTOR 2013, ALIAS 2013.
    If in doubt scale and don't ask!
  5. #5
    Forum Newbie
    Inventor 2010
    Sep 2009
    1
    Quote Originally Posted by Bill Tillman View Post
    Sure and easily, when you see how quickly he does a layout and save it to a dwg you'll drop autocad...fast... But yes, i do this all the time.
    I even create assembly from autocad 2D views. You simply place each views in each plan on a inventor part file and you can use your 2D stuff and built inventor models around it.
  1. consraints in inventor 2010 studio
    By matulja87 in forum Autodesk Inventor
    Last Post: 10th Jul 2009, 06:27 pm
  2. autocad 2007DWG - inventor 2010
    By cmjay83 in forum Autodesk Inventor
    Last Post: 1st Jul 2009, 05:44 pm
  3. Replies: 25
    Last Post: 30th Jun 2009, 10:05 am
  4. Replies: 0
    Last Post: 14th Jun 2009, 08:50 pm
  5. How do I work from AutoCAD 2010 to AutoCAD 2009 edition??
    By Meglesniak323 in forum AutoCAD General
    Last Post: 14th May 2009, 10:18 pm
