Results 1 to 5 of 5
    Senior Member
    AutoCAD 2002
    Oct 2008
    124
    Question Failed to perform blend?
    I'm filleting a 3D solid and got this message.
    Modeling Operation Error:
    Unable to complete sheet - blend may be too big.
    Failed to perform blend.
    Failure while filleting.
    What could be wrong with the object?
    Senior Member arjun_samar's Avatar
    AutoCAD 2009
    Dec 2008
    Samar,Philippines
    182
    Quote Originally Posted by marlon View Post
    try to set to a much lower value of radius...
    Forum Newbie
    AutoCAD 2008
    May 2010
    1
    Default Thank you
    Quote Originally Posted by arjun_samar View Post
    Hi there. I had the same problem when filleting a 3Dsolid. Not exactly the same but pretty much. I did what you said, and it worked just fine, the problem is: I need a higher value in order to make the fillet more obvious. More pronounced. I mean, a really lower value (I lowered it to .009) is useless to my intentions, I need something like a 0.5 radius. Any ideas? Thank you in advance.
    P.S. When I set it to a higher value, i got this message: Failure while filleting.
    Command: fillet
    Current settings: Mode = TRIM, Radius = 0.0000
    Select first object or [Undo/Polyline/Radius/Trim/Multiple]:
    Enter fillet radius: .5
    Select an edge or [Chain/Radius]:
    1 edge(s) selected for fillet.
    Command: fillet
    Enter fillet radius: .009
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Uhmm, attach the file here.
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Maybe the radius you're using is too large (at least to AutoCAD's way of thinking).
  1. What calculation does AutoCad perform to give Areas
    By grovenstien in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Apr 2009, 08:30 pm
  2. What function does the "OL" command perform?
    By rolso in forum AutoCAD General
    Last Post: 5th Nov 2008, 05:30 pm
  3. Dark Roasted Blend
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 25th May 2008, 10:12 am
  4. "blend" tool in illustrator
    By lily in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jan 2008, 10:05 pm
  5. Perform "Loft" or similar in acad 06?!
    By sam. in forum AutoCAD General
    Last Post: 19th Nov 2007, 06:22 pm
