Request for recommendations for best mouse for Vista
RONDO1020
I am a relative newcomer to Autocad and am about to begin using version 2007 with Vista. Any recommendations for the best mouse to use would be appreciated. I have read numerous reports of pan function not working correctly etc and would like to start off with a mouse without any compatability issues.
The razer mamba is probably the greatest mouse out there right now. But at a price of around $120 us dollars, it is steep.
specs of the mamba
  • Gaming Grade Wireless Technology
  • Dual Mode Wired/Wireless Functionality
  • Razer Synapse™ On-board Memory
  • Seven independently programmable Hyperesponse™ buttons
  • 5600DPI Razer Precision™ 3.5G Laser sensor
  • 1000Hz Ultrapolling™ / 1ms response rate
  • Up to 200 inches per second*/ 50g acceleration
  • Approximate size: 128mm x 70mm x 42.5mm
  • Battery Life: 14hrs (continuous gaming); 72 hours (normal gaming usage) *Depends on surface used
You can find a good razer mouse for around $30 to $40 US dollars.
The razer salmosa falls under this category.
here are the specs for it:
  • 1800dpi Razer Precision™ 3G infrared sensor
  • 1000Hz Ultrapolling / 1ms response time
  • Mechanical dpi/polling rate switches
  • On-The-Fly Sensitivity™ adjustment
  • Always-On™ mode
  • Ultra-large non-slip buttons
  • 16-bit ultra-wide data path
  • 60-120 inches per second
  • Three independently programmable Hyperesponse™ buttons
  • Ambidextrous design
  • Scroll wheel with 24 individual click positions
  • Zero-acoustic Ultraslick™ Teflon feet
  • Seven-foot, lightweight, non-tangle cord
  • Approximate size: 115mm (length) x 63mm (width) x 37mm (height)
i saw the mamba in the store, it's sooo nice and oh so comfortable.
specs of the mamba
  • Always-On™ mode
  • 2 weeks later...
http://www.logitech.com/index.cfm/mice_pointers/mice/devices/2987&cl=US,EN
i quite like this mouse. got it recently and i use autocad everyday :) seems to work great with me.
getting the correct mouse is all down to personal opinion though. theres only so much information from others but until you try a few out, you might not find "the one" :)
All I've read on this site points to Logitech as the preferred mouse. I'll search their website and find something suitable. Sounds like hand fit is the main concern.
Keep your scotch. We'll take all your Islay Whisky.
Reading the various reviews, the MX1100 sounds great. My original concern was how individual mouse features work with AutoCAD. I'm used to a 16 button cursor on a digitizing table but want to switch to a mouse. My sense is that the main thrust in mouse design is for ergonomics and that they all function fine within AutoCAD.
The SetPoint software that comes with the Logitech mice lets you program the buttons to specific tasks, specific for Autocad (and separately for other programs as well)
