Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 23
  1. #11
    Luminous Being alanjt's Avatar
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by seapea View Post
    I'm impressed with your quick reply. thanks
    ok, i run rhe lsp, select the block, see "abc", click to 'Specify opposite corner:', and it all goes away! What am I missing? Does this code go into the other lisp file test.lsp? confused
    Completely separate from the other routine and it should work fine - does on my end...
    DropBox
    Seann: ...it went crazy ex-girlfriend on me...
    eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak...
  2. #12
    Forum Newbie
    AutoCAD 2013
    Jun 2013
    2
    Hello,
    does anybody know, how to update this lisp code in a way, that the leader would not start at the block insertion point? I tried to delete some lines from the code, but ended up in AC crash
    thanks for help
  3. #13
    Civil 3D 2013
    Apr 2008
    6,199
    Quote Originally Posted by janickovic View Post
    Hello,
    thanks for help
    Code:
    (defun c:BNameLabel (/ ent entl obj)
      (cond ((not (setq ent (car (entsel "\nSelect block: ")))))
            ((not (eq (cdr (assoc 0 (entget ent))) "INSERT")) (princ "\nInvalid object!"))
            ((setq pt (getpoint "\nSpecify first point: "))
             (setq entl (entlast))
             (vl-cmdf "_.mleader" "_non" pt "\\")
             (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf ""))
             (if (not (equal entl (setq entl (entlast))))
               (vla-put-textstring
                 (vlax-ename->vla-object entl)
                 (vlax-get-property
                   (setq obj (vlax-ename->vla-object ent))
                   (if (vlax-property-available-p obj 'EffectiveName)
                     'EffectiveName
                     'Name
    (vl-load-com)
    DropBox
  4. #14
    Forum Newbie
    AutoCAD 2013
    Jun 2013
    2
    Hi,
    thanks, I figured it out in the mean time, nevermind. In addition, I updated the code, so now the leader can read attribute from a block and attach it to the name of the block. But I am getting some weird error about parameters and I would like to have ability to show more parameters, but I don't know the way how to do it (I learned list 10 years ago, in school, but my memory are not the good, I was only able to do this).
    Code:
    (defun c:TEST (/ #Entsel #InsPoint #Name #Desc #LandPoint)
      (if (setq
            #Entsel (AT:Entsel nil "\nSelect block: " '((0 . "INSERT")) nil)
          ) ;_ setq
          ;; convert to vla-object
          (setq #Entsel   (vlax-ename->vla-object (car #Entsel))
                ;; insertion point
                #InsPoint (vlax-safearray->list
                            (vlax-variant-value
                              (vla-get-InsertionPoint #Entsel)
                            ) ;_ vlax-variant-value
                          ) ;_ vlax-safearray->list
                ;; block name
                #Name     (vla-get-name #Entsel)
                ;; block description
                #Desc     (vla-get-comments
                            (vla-item
                              (vla-get-blocks
                                (vla-get-activedocument
    (vlax-get-acad-object))
                              ) ;_ vla-get-blocks
                              #Name
                            ) ;_ vla-item
                          ) ;_ vla-get-comments
           ) ;_ setq
          (cond
            ;; no description in block
            ((eq "" #Desc)
             (princ (strcat "\nNo description for block: \""
                            #Name
                    ) ;_ strcat
             ) ;_ princ
      (and
       (foreach att (vlax-invoke #Entsel 'GetAttributes)
         (eq "TAG" (vla-get-textstring att)
          (vl-cmdf "_.mleader" "_non" PAUSE "_non" PAUSE (strcat #Name (chr 10)
    (vla-get-textstring att)))
    ;   (vl-cmdf "_.mleader" "_non" PAUSE "_non" PAUSE #Name)
          ) ;_ cond
        ) ;_ progn
      ) ;_ if
    ) ;_ defun
  5. #15
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Please read the Code posting guidelines and use Code Tags for your Code.
  6. #16
    Forum Newbie
    Mechanical 2014
    Aug 2015
    1
    Default Multileader to Block
    Is there a way to do the opposite of this lisp? That is, create and then name a block based on its multileader callout)? [the block name would also be followed by a postscript]. I have about a thousand of these to do, each w/ a different name.
  7. #17
    Forum Newbie
    AutoCAD 2016
    May 2016
    4
    I tried, but is giving fatal error
  8. #18
    Forum Newbie
    Manufacture
    AutoCAD 2017
    Nov 2017
    2
    Default Were you able to figure this out?
  9. #19
    Forum Newbie
    Manufacture
    AutoCAD 2017
    Nov 2017
    2
    Default OHHH... Nevermind.
    Quote Originally Posted by MPEREZ View Post
    I see that I was not using the correct command.
  10. #20
    Forum Newbie
    Mechanical
    AutoCAD 2008
    Dec 2017
    3
    Hello
    I'm using the code from post #13 and I would like to modify it a bit.
    All the blocks in my the drawing have an attribute named "TAG" and I would like to show that value instead of the block name.
    Can anyone help me please. Thanks.
  1. Leader/text to multileader
    By pmcwilliams in forum AutoCAD General
    Last Post: 30th Aug 2017, 04:26 pm
  2. Multileader with block content
    By dinarele in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Aug 2009, 03:07 pm
  3. Multileader text
    By alijahed in forum AutoCAD General
    Last Post: 2nd Mar 2009, 09:58 am
  4. Cannot Edit Multileader Text
    By rustysilo in forum AutoCAD General
    Last Post: 2nd Feb 2009, 04:38 pm
  5. Multileader text at arrowhead end?
    By bbohannon1 in forum AutoCAD General
    Last Post: 13th Oct 2008, 07:11 pm
