Results 1 to 2 of 2
    Full Member
    AutoCAD 2010
    Jan 2009
    48
    Default How to set view as per object face.
    Normally views are set by default. I made a drawing in which my object is rotated from top> <45.
    Kindly give me a way to set view as per face of object.
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    So rotate the UCS with 45deg.
    Enter the UCS command and play around with those options.
    You can either Rotate the UCS, or Align it with an object in the drawing.
    After the UCS is in place, use the PLAN command.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  1. trying to put a 3d face on top of this object...
    By sarah in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Feb 2009, 12:49 pm
  2. Replies: 1
    Last Post: 26th Jun 2008, 06:32 am
  3. how to 3d face a curved object
    By mafioso in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Mar 2008, 10:26 pm
  4. Getting same view in all the viewports for a 3D object ?
    By anayal in forum AutoCAD Beginners' Area
    Last Post: 6th Nov 2007, 12:52 pm
  5. Difference between Extrude face, offset face and move face
    Last Post: 12th Oct 2007, 12:17 am
