Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 22
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Extrude is a term used in 3D. Extruding an object gives it height.
    I'm not familiar with Gear Factory 6 but I'm pretty sure I saw a lisp routine somewhere that somewhat automates the process of drawing a gear.
    Is GF6 an add-on to AutoCAD?
  2. #12
    Forum Newbie
    AutoCAD not applicable
    Aug 2009
    6
    Ok, thanks for that. Do you think I should live that "Gear Factory" alone?
    Remark: cwattsdesign.com/gearfactory.htm
  3. #13
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Gear Factory 6 is compatibile with AutoCAD. And it seems rather inexpensive too. What version AutoCAD are you using?
    http://www.softpedia.com/get/Science...-Factory.shtml
  4. #14
    Super Member chelsea1307's Avatar
    chelsea1307's Computer Details
    windows xp
    AutoCAD 2011
    Sep 2008
    Sacramento, Ca USA
    1,109
    another thing to consider is how often will you be drawing these gears? If its just this once, i would just create it with autocad if its something you will be doing multiple times a day/week then you might want to get the program
    "The problem is stupidity. I am not saying there should be capital punishment for stupidity, but, why don't we just take the safety labels off of everything and let the problem solve itself? "
  5. #15
    windows xp
    AutoCAD 2011
    Sep 2008
    Sacramento, Ca USA
    1,109
    found a free lisp to draw gears at http://www.cadmonkey.com/lisp.htm find the gear.zip and download it will be 2d but then you can extrude to 3d, and its free
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    You can download gear.lsp from here. It's for 2D. You'd have to do the rest yourself to get a 3D solid from it.
    http://www.beowolftech.com/lispgen/examples.html
  7. #17
    Forum Newbie
    Aug 2009
    6
    Ok, Thanks again. I will look into this more tomorrow and I will post how it goes.
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Sorry Chelsea. Didn't mean to step on your toes (or fingers). Bit of a time lag for some reason today on my part.
  9. #19
    windows xp
    AutoCAD 2011
    Sep 2008
    Sacramento, Ca USA
    1,109
    not a problem, you usually beat me (and most people) to the answer
  10. #20
    Full Member
    AutoCAD 2011
    Jun 2009
    Canada
    32
    Dray one tooth and then type AR and ENTER . In the array box select POLAR and type 360 degrees and select the gear ,and then you need to select the center of the rotation so a circle drawn already and the gear positioned on that circle will help ,then AutoCAD draws them all for you . You may need a couple attempts to get the alingment correct. Then use the EXT command (extrude)and select the gear and it will prompt for Height which refers to the thickness of the sprocket or gear and turns it into a 3D solid.
    Hope that helps.
  1. how to draw a spur gear in AutoCAD 2004
    By freaker2005 in forum AutoCAD General
    Last Post: 14th Jul 2014, 02:25 pm
  2. Making a gear
    By NaeKid in forum AutoCAD General
    Last Post: 4th Apr 2009, 01:47 am
  3. gear help
    By bolton78 in forum AutoCAD Beginners' Area
    Last Post: 23rd Jun 2008, 10:08 pm
  4. how do i draw a gear
    By alain in forum AutoCAD General
    Last Post: 24th Sep 2006, 10:21 pm
