Results 1 to 5 of 5
    Junior Member
    not specified
    Aug 2005
    20
    Default reconized mouse click or enter
    Hi people, I need autocad o any function reconized click mouse or enter buttom:example:
    var=thisDrawing.Utility.GetPoint("Point final")
    if clickMouse then
    call functionX()
    elseif enterButtom then
    call FunctionY()
    end if
    Thanx!!!
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,548
    In plain Autolisp it would look like this:
    Code:
    (while (setq pt (getpoint "\nPick Point:   ))
           (then-do_this))
    (else_so_that)
    This would also allow keyboard input of a point value. -David
    R12 (Dos) - A2K
    Junior Member
    not specified
    Aug 2005
    20
    Quote Originally Posted by David Bethel
    Code:
           (then-do_this))
    (else_so_that)
    Sorry , I forgot to say in visual basic, thanx!!
    Forum Newbie
    not specified
    Sep 2005
    Jacksonville, Florida
    2
    I believe you will need to use the API.
    An example
    The following must be in a Module
    Public Const MK_RBUTTON = &H2
    Public Const VK_RETURN = &HD 'enter
    Public Const VK_ESCAPE = &H1B 'escape
    Public Declare Function GetAsyncKeyState Lib "USER32" (ByVal vKey As Long) As Integer
    The following should be in your thisdrawing object
    Private Sub Key_Test()
    'note use "ESC" key to exit sub
    Dim RightCLick As Boolean
    Dim EnterKey As Boolean
    On Error GoTo err_control
    MyLoop:
    If RightCLick Then
    MsgBox "right click"
    RightCLick = False
    End If
    If EnterKey Then
    MsgBox "enter key"
    EnterKey = False
    End If
    Pnt1 = ThisDrawing.Utility.GetPoint(, "First Point")
    GoTo MyLoop
    err_control:
    If GetAsyncKeyState(VK_ESCAPE) Then
    Exit Sub
    End If
    If GetAsyncKeyState(MK_RBUTTON) Then
    RightCLick = True
    Resume MyLoop
    End If
    If GetAsyncKeyState(VK_RETURN) Then
    EnterKey = True
    Resume MyLoop
    End If
    End Sub
  5. #5
    Junior Member
    not specified
    Aug 2005
    20
    Thank you very much!!
