Circle-Isometric Snap
Hello everybody,
In Isometric Snap mode, the " Circle " is not coming parrallel to the plane.what should be the reason? please advise. ( check the attachment) Thank you.
Regards_____:)
Thanks for your replay,
Did you try this method to draw circle.it's not working.instead of hitting " F5 " i used " ctrl+E ".but my friend it's not working.i am using autocad Lt.may be this could be the reason? or somethingelse?
Thankyou.
Regards______:)
I have the cursor adjusted to fit the following circle. I used the F5 key as well... It works with my Architectural desktop.... See the attached image:
But it's still not working in Autocad Lt and autocad 2009.I have to adjust any settings.i tried both softwares.please advise.Thank you.
Regards_____:(
Isometric circles can be generated through Ellipse-Isocircles.
Command: _ellipse
Specify axis endpoint of ellipse or [Arc/Center/Isocircle]: I
Specify center of isocircle:
Specify radius of isocircle or [Diameter]:
Command: _ellipse
Thanks for that!! This drawing is a year old I completely forgot that I used and ellipse!
-Steven
It is a bit unintuitive that AutoDesk only included that sub-option with the Ellipse command. I understand why it's referenced with ellipse, but they could have included that feature in the Circle sub-options as well.
I haven't had to use it yet, but I would assume that Autodesk would keep the ellipse sub-options like in 2004... correct?
Not 100% sure but I THINK that 2004's ellipses have the same sub-menu - as havent used it for a while i can't quite remember
Allow me to edit that:
I haven't had to use it yet, but I would assume that Autodesk would keep the ellipse sub-options like in 2004 in the 2010 software... correct?
