How do I calculate the closest point on an arc to a selected point?
Hudson
Is the most efficient to do this to test every point on the arc in a loop?
Or is there a better way?
Thanks for any and all input
Andrew
As an example:
(defun c:test (/ pt ent cLs)
 (vl-load-com)
 (if (and (setq ent (car (entsel "\nSelect an Object: ")))
          (setq pt (getpoint "\nSelect a Point to Test: ")))
     (setq cLs (vlax-curve-getClosestPointto ent pt))
     ;; --  Display Point  --
     (setvar "PDMODE" 34)
     (vla-addPoint
       (vla-get-ModelSpace
         (vla-get-ActiveDocument
           (vlax-get-acad-object)))
       (vlax-3D-point cLs))))
 (princ))
  • 2 years later...
If memory serves VLAX specifies a Visual LISP ActiveX function prefix. ... It (my memory) didn't. :rofl: See next post.
** Edit - Just wanted to get my guess in before Lee's (correct) answer. :P LoL
Aha... Found it!
Lee's post here clarifies the different function prefixes that Visual LISP uses. :thumbsup:
Thanks. They are far beyond my knowledge and I don't think I can use them.
Not at all... It may just take some time to understand how they work, and how to properly use them. :)
Have you tried Lee's code in post #4? :unsure:
